Help with IPDM241-3OI camera
ZioTibia81
Post by ZioTibia81 »
Hi!
I'm doing some tests with a cuple of IPDM241-3OI cameras.
My sistem use ubuntu 17.10 and distribution standard build of zm.
I've tested many configurations:
Camera settings for H264 stream
  1. Method FFMPEG rtsp://admin:1111@ip/av0_0
    It works but take a lot of cpu (2 cams 70% of cpu)
  2. Method Remote RTP/RTSP - TCP
    It take a little less cpu but log many errors like:
    "8: 00 00 01 06 e5 01 15 80 zm_remote_camera_rtsp.cpp ERR Error while decoding frame 3700"
    and ZM crash after a some hours
  3. Method libvlc desn't work
Camera settings for MJPEG stream
    It desn't work and report error:
    Error while decoding frame 0
    ERR: 256 00 00 00 00 01 ff f0 .....
  3. Method libvlc works, take a little less cpu than ffmpeg but flood syslog of entry like:
    jpeg @ 0x7f6eb4046540
    JPEG data found in image
How I can reduce cpu usage?
Re: Help with IPDM241-3OI camera
Lower the fps in the camera, lower the resolution (in the camera) or get a more power cpu.
Or pay someone lots of money to make hardware h264 decoding work.
ZioTibia81
I will try your first suggestion, last one is a little bit hard for me....
