Control script and URL for D-Link DCS-5220B1
link83
Post by link83 » Thu Oct 19, 2017 5:10 pm
I recently wrote a control script for my D-Link DCS5220B1, and i though it might be a good idea to share it with people around here. I wanted to add it to the Wiki but i can't find the "register" page so i decided to release it here.
Here is the script :
# ZoneMinder D-Link DCS-5220B1 Control Protocol Module, $Date$, $Revision$
# Copyright (C) 2001-2008  Philip Coombes
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA  02111-1307, USA.
# This module contains the implementation of the D-Link DCS-5220B1 camera control
# protocol
package ZoneMinder::Control::DCS5220B1;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# DCS-5220B1 Control Protocol
use Time::HiRes qw( usleep );
sub new
    my $class = shift;
    my $id = shift;
    bless( $self, $class );
    srand( time() );
    return $self;
our $AUTOLOAD;
sub AUTOLOAD
    my $self = shift;
    my $name = $AUTOLOAD;
    $name =~ s/.*://;
    if ( exists($self->{$name}) )
        return( $self->{$name} );
sub open
    my $self = shift;
    $self->loadMonitor();
    use LWP::UserAgent;
    $self->{ua}->agent( "ZoneMinder Control Agent/".ZoneMinder::Base::ZM_VERSION );
    $self->{state} = 'open';
sub close
    my $self = shift;
    $self->{state} = 'closed';
sub printMsg
    my $self = shift;
    my $msg = shift;
    my $msg_len = length($msg);
sub sendCmd
    my $self = shift;
    my $cmd = shift;
    my $result = undef;
    printMsg( $cmd, "Tx" );
    if ( $res->is_success )
        $result = !undef;
    else
    return( $result );
sub cameraReset
    my $self = shift;
    Debug( "Camera Reset" );
    my $cmd = "/admin/setparam.cgi?System_reset=0";
    $self->sendCmd( $cmd );
sub moveConUp
    my $self = shift;
    Debug( "Move Up" );
    my $cmd = "/viewer/camctrl.cgi?move=up";
sub moveConDown
    my $self = shift;
    Debug( "Move Down" );
    my $cmd = "/viewer/camctrl.cgi?move=down";
sub moveConLeft
    my $self = shift;
    Debug( "Move Left" );
    my $cmd = "/viewer/camctrl.cgi?move=left";
sub moveConRight
    my $self = shift;
    Debug( "Move Right" );
    my $cmd = "/viewer/camctrl.cgi?move=right";
sub presetHome
    my $self = shift;
    Debug( "Home Preset" );
    my $cmd = "/viewer/camctrl.cgi?move=home";
1;
__END__
# Below is stub documentation for your module. You'd better edit it!
=head1 NAME
ZoneMinder::Database - Perl extension for blah blah blah
=head1 SYNOPSIS
  use ZoneMinder::Database;
  blah blah blah
=head1 DESCRIPTION
Stub documentation for ZoneMinder, created by h2xs. It looks like the
author of the extension was negligent enough to leave the stub
unedited.
Blah blah blah.
=head2 EXPORT
None by default.
=head1 SEE ALSO
Mention other useful documentation such as the documentation of
related modules or operating system documentation (such as man pages
in UNIX), or any relevant external documentation such as RFCs or
standards.
If you have a mailing list set up for your module, mention it here.
If you have a web site set up for your module, mention it here.
=head1 AUTHOR
Philip Coombes, E<lt>philip.coombes@zoneminder.comE<gt>
=head1 COPYRIGHT AND LICENSE
This library is free software; you can redistribute it and/or modify
it under the same terms as Perl itself, either Perl version 5.8.3 or,
at your option, any later version of Perl 5 you may have available.
=cut
Settings to use :
Control tab (on the monitor window)
  • Control address : <user>:<pwd>@<IP>:<port>
  • Return location : home
Main tab
  • Type : remote
Move
  • Can move : yes
  • Can move continuous : yes
Pan
  • Can pan
  • Has pan speed : yes
  • Min pan speed : -5
  • Max pan speed : 5
Tilt
  • Can tilt
  • Has tilt speed : yes
  • Min tilt speed : -5
  • Max tilt speed : 5
Presets tab
  • Has presets : yes
  • Num presets : 0
  • Has home presets : yes
I'm not an expert at all and created this script using an existing one and this PDF. The script probably needs some improvements but as is it is good for me (better than nothing !)
The URL setting for streaming are :
  • Source type : remote
  • Remote protocol : RTSP
  • Remote method : RTP/RTSP
  • Remote host name : <user>:<pwd>@<IP>
  • Remote host port : 554
  • Remote host path : live.sdp or live2.sdp
  • Capture width : 640
  • Capture height : 480
  • Use RTSP response media URL : yes
It all works for me on zoneminder 1.29 and 1.30.
I hope it can help.
