hello
someone has a working dsc-5222l with ptz in zoneminder?
what do i have to do? where do i get the script? how do i have to install it?
thx
d‘link dsc 5222l ptz
Re: d‘link dsc 5222l ptz
I have had success with various cameras and PTZ control using a generic script.
download and then remove the fake .gz extension and place the IPCAM.pm into /usr/share/perl5/zoneminder/control
then open the camera settings window and open the Control tab (make sure in Options->System->OPT_CONTROL is checked and selected).
check the Controllable box and on the next line Control Type click "edit"
here select add new control and for "name" and "protocol" type "IPCAM"
open the movement tabs and select can move can tilt can pan then "SAVE"
then in the camera settings window pick the new IPCAM and fill in the URL for the camera.
I had to fiddle around with it but along these lines is how I got it to work. There may be a d-link specific control script but I have not found one and have not looked in awhile.
let us know how you make out!
- IPCAM.pm.gz
- (11.45 KiB) Downloaded 94 times
many heartfelt thanks for your reply
unfortunately it did not work, but I have found a solution
if someone else is looking for a solution, i used the attached script:
and this settings:
Main
Name: Dlink DCS-5222LB
Type: Local
Protocol: DCS_5222LB
Move
Can Move: yes
Can Move Diagonally: yes
Can Move Mapped: yes
Can Move Absolute: no
Can Move Relative: yes
Can Move Continuous: no
Pan also Tilt
Can Pan/Tilt: yes
Min Pan/Tilt Range: 0
Max Pan/Tilt Range: 0
Min Pan/Tilt Step: 1
Max Pan/Tilt Step: 30
Has Pan/Tilt Speed: no
Min Pan/Tilt Speed: 0
Max Pan/Tilt Speed: 0
Has Turbo Pan/Tilt: No
Turbo Pan/Tilt Speed: 0
maybe that can help someone
thanks and greetings
and this settings:
Main
Type: Local
Move
Can Move: yes
Pan also Tilt
Can Pan/Tilt: yes
yes that does help! Definitely increasing the available control scripts is also a plus and configuration info with working examples is valuable
