Page 1 of 2
Camera shows no picture. Socket does not exist
Posted: Sun Oct 01, 2017 9:24 am
by jannnfe
I'm trying to get my new camera with Zoneminder to run for days. I already have as much as everything I have found on the internet to get zoneminder to run.
I have installed zone minder like this:
The camera settings think I am right in zoneminder. It is the Wanscam JW0011 camera and with another service the camera with the same settings shows a picture.
I'm not sure if the connection to cgi-bin is correct in my system. I have however also still no possibility found this out.
I have already changed the PATH_ZMS to /zm/cgi-bin/nph-zms
In ZoneMinder log i get this errors:
Socket /var/run/zm/zms-337020s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information
getStreamCmdResponse stream error: Socket /var/run/zm/zms-337020s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. - checkStreamForErrors()
Unable to get response, disconnecting
Unable to read subheade
Select error: Interrupted system call
But on the other hand I get these messages in the log. So actually it should work?
Garagentuer: 1000 - Capturing at 23.26 fps
Garagentuer: 2000 - Capturing at 22.73 fps
This is my zoneminder.conf in apache2:
AllowOverride All
Require all granted
</Directory>
<IfModule mod_dir.c>
DirectoryIndex index.php
</IfModule>
</Directory>
AllowOverride All
</Directory>
I have already done a2enmod cgi and its saying its running
I hope someone can help me to bring my camera to run.
Thanks!
Re: Camera shows no picture. Socket does not exist
Posted: Sun Oct 01, 2017 1:06 pm
by Baylink
Look in either
/var/log/apache/error_log or /var/log/httpd/error_log
whichever you have, and see what error is showing up when you call nph-zms.
That should be a hint what isn't configured correctly -- which is usually what this is.
Posted: Sun Oct 01, 2017 2:11 pm
by jannnfe
error.log gives me the same as in the Zoneminder Webinterface Log:
[Sun Oct 01 16:05:19.608384 2017] [:error] [pid 6817] [client 192.168.178.130:63932] INF [Login successful for user "root"], referer: http://192.168.178.10/zm/
[Sun Oct 01 16:05:31.378023 2017] [access_compat:error] [pid 1416] [client 192.168.178.130:63937] AH01797: client denied by server configuration: /usr/lib/zoneminder/cgi-bin/nph-zms, referer: http://192.168.178.10/zm/index.php?view=watch&mid=2
[Sun Oct 01 16:05:31.483347 2017] [access_compat:error] [pid 6818] [client 192.168.178.130:63933] AH01797: client denied by server configuration: /usr/lib/zoneminder/cgi-bin/nph-zms, referer: http://192.168.178.10/zm/index.php?view=watch&mid=2
[Sun Oct 01 16:05:42.676278 2017] [:error] [pid 2075] [client 192.168.178.130:63939] ERR [Socket /var/run/zm/zms-752901s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.], referer: http://192.168.178.10/zm/index.php?view=watch&mid=2
[Sun Oct 01 16:05:42.685682 2017] [access_compat:error] [pid 2075] [client 192.168.178.130:63939] AH01797: client denied by server configuration: /usr/lib/zoneminder/cgi-bin/nph-zms, referer: http://192.168.178.10/zm/index.php?view=watch&mid=2
[Sun Oct 01 16:05:54.699581 2017] [:error] [pid 1415] [client 192.168.178.130:63943] ERR [Socket /var/run/zm/zms-752901s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information.], referer: http://192.168.178.10/zm/index.php?view=watch&mid=2
Posted: Sun Oct 01, 2017 6:41 pm
by Baylink
Not quite. 'Client denied by server config' is the important sentence there, and it means that your Apache configuration is messed up somehow.
Posted: Sun Oct 01, 2017 11:20 pm
by jannnfe
Thats good to Know. Thank you.
How can i find the mistake.
Some ideas? Can i share my configurations of my Apache?
Thanks!
Posted: Mon Oct 02, 2017 7:58 am
by marcopete87
in my servers (ubuntu and debian), usually i do this:
cd /usr/lib/cgi-bin
ln -s /usr/lib/zoneminder/cgi-bin/zms zms
ln -s /usr/lib/zoneminder/cgi-bin/zms nph-zms
This will link zoneminder cgi to apache cgi.
Remember to set correct permissions with chmod!
Posted: Mon Oct 02, 2017 8:22 am
by jannnfe
I get this:
root@homeserver:/usr/lib/cgi-bin# ls
nph-zms
root@homeserver:/usr/lib/cgi-bin# ln -s /usr/lib/zoneminder/cgi-bin/zms zms
root@homeserver:/usr/lib/cgi-bin# ln -s /usr/lib/zoneminder/cgi-bin/zms nph-zms
ln: failed to create symbolic link 'nph-zms': File exists
root@homeserver:/usr/lib/cgi-bin# cd /usr/lib/zoneminder/cgi-bin
root@homeserver:/usr/lib/zoneminder/cgi-bin# ls
nph-zms zms
The ln -s /usr/lib/zoneminder/cgi-bin/zms nph-zms failed.
And what are the right permissions to set?
Thanks!
Posted: Mon Oct 02, 2017 8:16 pm
by jkwan
Hi all,
I have found this on another board.
https://bugs.launchpad.net/ubuntu/+sour ... ug/1159361
I have the same issue as you. It seems that the problem is the authentification.
I have set the AUTH_RELAY to <none> in OPTIONS > SYSTEM and it works.
The question is ZM secure whith this configuration ?
Posted: Mon Oct 02, 2017 9:24 pm
by jannnfe
Thanks for your reply.
Nothing of this helped me to find my miss configuration.
I am slowly despairing I still get the same error messages as in my first post.
My /etc/apache2/conf-enabled/zoneminder.conf
#ScriptAlias /zm/cgi-bin "/usr/lib/zoneminder/cgi-bin"
ScriptAlias /zoneminder/cgi-bin "/usr/lib/zoneminder/cgi-bin"
AllowOverride All
Require all granted
</Directory>
</IfModule>
</Directory>
AllowOverride All
</Directory>
My /etc/apache2/apache2.conf
# Global configuration
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# NOTE! If you intend to place this on an NFS (or otherwise network)
# mounted filesystem then please read the Mutex documentation (available
# at <URL:http://httpd.apache.org/docs/2.4/mod/core.html#mutex>);
# you will save yourself a lot of trouble.
# Do NOT add a slash at the end of the directory path.
#ServerRoot "/etc/apache2"
# The accept serialization lock file MUST BE STORED ON A LOCAL DISK.
Mutex file:${APACHE_LOCK_DIR} default
# PidFile: The file in which the server should record its process
# identification number when it starts.
# This needs to be set in /etc/apache2/envvars
PidFile ${APACHE_PID_FILE}
# Timeout: The number of seconds before receives and sends time out.
Timeout 300
# KeepAlive: Whether or not to allow persistent connections (more than
# one request per connection). Set to "Off" to deactivate.
KeepAlive On
# MaxKeepAliveRequests: The maximum number of requests to allow
# during a persistent connection. Set to 0 to allow an unlimited amount.
# We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
# KeepAliveTimeout: Number of seconds to wait for the next request from the
# same client on the same connection.
KeepAliveTimeout 5
# These need to be set in /etc/apache2/envvars
User ${APACHE_RUN_USER}
Group ${APACHE_RUN_GROUP}
# HostnameLookups: Log the names of clients or just their IP addresses
# e.g., www.apache.org (on) or 204.62.129.132 (off).
# The default is off because it'd be overall better for the net if people
# had to knowingly turn this feature on, since enabling it means that
# each client request will result in AT LEAST one lookup request to the
# nameserver.
HostnameLookups Off
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here. If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog ${APACHE_LOG_DIR}/error.log
# LogLevel: Control the severity of messages logged to the error_log.
# Available values: trace8, ..., trace1, debug, info, notice, warn,
# error, crit, alert, emerg.
# It is also possible to configure the log level for particular modules, e.g.
# "LogLevel info ssl:warn"
LogLevel warn
# Include module configuration:
IncludeOptional mods-enabled/*.load
IncludeOptional mods-enabled/*.conf
# Include list of ports to listen on
IncludeOptional ports.conf
# Sets the default security model of the Apache2 HTTPD server. It does
# not allow access to the root filesystem outside of /usr/share and /var/www.
# The former is used by web applications packaged in Debian,
# the latter may be used for local directories served by the web server. If
# your system is serving content from a sub-directory in /srv you must allow
# access here, or in any related virtual host.
<Directory />
Order deny,allow
deny from all
Options FollowSymLinks
AllowOverride None
Require all denied
</Directory>
<Directory /usr/share>
Order allow,deny
allow from all
AllowOverride All
Require all granted
</Directory>
#<Directory /var/www/>
# Options Indexes FollowSymLinks
# AllowOverride All
# Require all granted
#</Directory>
<Directory /home/webserver/>
Order allow,deny
allow from all
AllowOverride None
Require all granted
</Directory>
<Directory /home/*/public_html/>
Order allow,deny
allow from all
AllowOverride None
Require all granted
</Directory>
Alias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
AddHandler cgi-script cgi pl
Order allow,deny
Allow from all
Require all granted
</Directory>
# AccessFileName: The name of the file to look for in each directory
# for additional configuration directives. See also the AllowOverride
# directive.
AccessFileName .htaccess
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<FilesMatch "^\.ht">
Require all denied
</FilesMatch>
# The following directives define some format nicknames for use with
# a CustomLog directive.
# These deviate from the Common Log Format definitions in that they use %O
# (the actual bytes sent including headers) instead of %b (the size of the
# requested file), because the latter makes it impossible to detect partial
# requests.
# Note that the use of %{X-Forwarded-For}i instead of %h is not recommended.
# Use mod_remoteip instead.
LogFormat "%v:%p %h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
LogFormat "%h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %O" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
# Include of directories ignores editors' and dpkg's backup files,
# see README.Debian for details.
# Include generic snippets of statements
IncludeOptional conf-enabled/*.conf
# Include the virtual host configurations:
IncludeOptional sites-enabled/*.conf
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
My /etc/zm/zm.conf
# ZoneMinder Base Configuration, $Date$, $Revision$
# This file is generated by 'configure'. Care should be taken if manually
# editing this file as an changes may be overwritten by subsequent configuration
# or installations.
# Path to installed data directory, used mostly for finding DB upgrade scripts
ZM_PATH_DATA=/usr/share/zoneminder
# Path to ZoneMinder binaries
ZM_PATH_BIN=/usr/bin
# Path to ZoneMinder libraries (none at present, for future use)
ZM_PATH_LIB=/usr/lib/x86_64-linux-gnu
# Path to ZoneMinder configuration (this file only at present)
ZM_PATH_CONF=/etc/zm
# Path to ZoneMinder web files
ZM_PATH_WEB=/usr/share/zoneminder/www
# Path to ZoneMinder cgi files
ZM_PATH_CGI=/usr/lib/zoneminder/cgi-bin
# Username and group that web daemon (httpd/apache) runs as
ZM_WEB_USER=www-data
ZM_WEB_GROUP=www-data
# ZoneMinder database type: so far only mysql is supported
ZM_DB_TYPE=mysql
# ZoneMinder database hostname or ip address and optionally port or unix socket
# Acceptable formats include hostname[:port], ip_address[:port], or localhost:unix_socket
ZM_DB_HOST=localhost
# ZoneMinder database name
ZM_DB_NAME=zm
# ZoneMinder database user
ZM_DB_USER=zmuser
# ZoneMinder database password
ZM_DB_PASS=zmpass
# Do NOT set ZM_SERVER_HOST if you are not using Multi-Server
# You have been warned
# The name specified here must have a corresponding entry
# in the Servers tab under Options
ZM_SERVER_HOST=
My options in Zoneminder for my Wanscam JW0011 Camera
- Bildschirmfoto 2017-10-02 um 23.21.02.png (61.6 KiB) Viewed 14915 times
- Bildschirmfoto 2017-10-02 um 23.21.28.png (65.34 KiB) Viewed 14915 times
Hope anybody can help me to get Zoneminder working without the hundreds of errors from my first post.
Thank you very much!
Posted: Tue Oct 03, 2017 1:41 am
by bbunge
If you followed the install instructions in the WIKI to the letter you should have a working Zoneminder. Mis one step and your system will be toast!
As for the camera setup you should use ffmpeg with modern cameras. Get the video to show in VLC, note the access string and reported resolution, transfer those settings to Zonemimder and voila! Your system will work!!!
You may be ahead to reinstall Ubuntu server or minimal system then do Zoneminder by the numbers again. Add LAMP from tasksel at initial install or afterwards and it will configure itself to work. Try not to waste time with obscure changes recommended by other web sites. I run these installs often to insure they work!
Edit: I just noticed a well meaning person made some changes to the WIKI instructions. I've undone their changes but am unable to test the install as my test computers have not arrived back home from an unsuccessful family move. Hope to be able to get you firm info by the weekend.
bb
Posted: Tue Oct 03, 2017 10:13 am
by jannnfe
I followed this instructions to install my camera:
https://wiki.zoneminder.com/Wanscam_FR4020A2_Out
But i think i find the problem of not getting a video stream and for the error.
When I open the View Window of my camera in zoneminder and i right click on the video element and open it in a new tab i get this message:
Forbidden
You don't have permission to access /zoneminder/cgi-bin/nph-zms on this server.
I found that same problem here but i can't figure out what i have to do to fix the permission problem
viewtopic.php?t=23715
Thanks for your help!
Posted: Wed Oct 04, 2017 2:20 am
by bbunge
I ment the WIKI instructions to install Zoneminder!
Posted: Wed Oct 04, 2017 2:33 pm
by Baylink
Jannnfe: "/zoneminder/" is an unusual thing to see in that pathname; it's customarily /zm/.
Did you pick /zoneminder/ in your install on purpose?
Posted: Thu Oct 05, 2017 6:33 pm
by jannnfe
Baylink wrote: ↑Wed Oct 04, 2017 2:33 pm
In my /etc/apache2/conf-enabled/zoneminder.conf i now have this Alias:
And my PATH_ZMS is now /zm/cgi-bin/nph-zms but same permission Problem as described above.
I get also in the log no error message, except when I open the window in which the stream of the camera should run.
Before open the Stream Window:
2017-10-05 20:27:55.284930 zma_m2 59271 INF Garagentuer: 150000 - Analysing at 10.99 fps
2017-10-05 20:27:35.840085 zmc_m2 59262 INF Garagentuer: 150000 - Capturing at 11.11 fps
2017-10-05 20:26:24.906840 zma_m2 59271 INF Garagentuer: 149000 - Analysing at 11.11 fps
2017-10-05 20:26:05.465245 zmc_m2 59262 INF Garagentuer: 149000 - Capturing at 11.11 fps
2017-10-05 20:24:54.524574 zma_m2 59271 INF Garagentuer: 148000 - Analysing at 11.11 fps
2017-10-05 20:24:35.083323 zmc_m2 59262 INF Garagentuer: 148000 - Capturing at 10.99 fps
2017-10-05 20:23:24.145213 zma_m2 59271 INF Garagentuer: 147000 - Analysing at 10.99 fps
2017-10-05 20:23:04.706638 zmc_m2 59262 INF Garagentuer: 147000 - Capturing at 11.11 fps
2017-10-05 20:22:11.234375 zma_m2 59271 INF Garagentuer: 146193 - Closing event 114, alarm end
2017-10-05 20:22:11.232547 zma_m2 59271 INF Garagentuer: 146193 - Left alarm state (114) - 62(11) images
2017-10-05 20:22:08.957802 zma_m2 59271 INF Garagentuer: 146168 - Gone into alert state
2017-10-05 20:22:08.874793 zma_m2 59271 INF Garagentuer: 146167 - Gone back into alarm state
2017-10-05 20:22:08.796182 zma_m2 59271 INF Garagentuer: 146166 - Gone into alert state
2017-10-05 20:22:07.907618 zma_m2 59271 INF Garagentuer: 146156 - Opening new event 114, alarm start
2017-10-05 20:22:07.903897 zma_m2 59271 INF Garagentuer: 146156 - Gone into alarm state
2017-10-05 20:21:53.771468 zma_m2 59271 INF Garagentuer: 146000 - Analysing at 11.11 fps
2017-10-05 20:21:34.325337 zmc_m2 59262 INF Garagentuer: 146000 - Capturing at 10.99 fps
2017-10-05 20:20:23.393244 zma_m2 59271 INF Garagentuer: 145000 - Analysing at 11.11 fps
2017-10-05 20:20:03.945371 zmc_m2 59262 INF Garagentuer: 145000 - Capturing at 11.11 fps
2017-10-05 20:20:03.216609 web_php 49044 INF Login successful for user "root"
After:
2017-10-05 20:30:43.323678 web_php 49045 ERR Socket /var/run/zm/zms-159706s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php
2017-10-05 20:30:42.438325 web_php 49046 ERR Socket /var/run/zm/zms-159706s.sock does not exist. This file is created by zms, and since it does not exist, either zms did not run, or zms exited early. Please check your zms logs and ensure that CGI is enabled in apache and check that the PATH_ZMS is set correctly. Make sure that ZM is actually recording. If you are trying to view a live stream and the capture process (zmc) is not running then zms will exit. Please go to http://zoneminder.readthedocs.io/en/latest/faq.html#why-can-t-i-see-streamed-images-when-i-can-see-stills-in-the-zone-window-etc for more information. /usr/share/zoneminder/www/includes/functions.php
2017-10-05 20:30:40.877813 web_js 49045 ERR getStreamCmdResponse stream error: socket_bind( /var/run/zm/zms-159706w.sock ) failed: Address already in use - checkStreamForErrors() ?view=watch
2017-10-05 20:30:40.863721 web_php 49045 ERR socket_bind( /var/run/zm/zms-159706w.sock ) failed: Address already in use /usr/share/zoneminder/www/includes/functions.php 2033
Posted: Thu Oct 05, 2017 6:37 pm
by Baylink
Check the filesystem permissions all the way along the path to
and make sure *the webserver owner user* has permission to search to there and execute. It sounds like your filesystem permissions have gotten ganked somewhere.
