Source status with multi-server
fujay
Post by fujay »
So far, I've been able to get ZoneMinder to do what we need it to do (with some challenges), but this one may be getting into the internals of ZoneMinder.
I recently added a second server, as the number of cameras we're looking at are going to require we spread the load around. I followed the instructions for multi-server setup, and it's working just fine. The only thing is, when I log into the web console, any monitor sources not on the server I logged into show red. So, if I log into server #0, the monitor sources for those on server #1 show red. And the opposite is also true: if I log into server #1, the monitors on server #0 have their sources show red.
The log shows no errors, all monitors are working properly, and I can view the monitors when logged into either server. The very only issue is how the source status is displayed.
I'd like to have a consistent view across servers. Did I miss something?
We're running 1.30.4 on Centos7, installed from the zmrepo as provided by zmrepo-7-9.el7.centos.noarch.rpm.
Thanks!
Re: Source status with multi-server
No that feature has not been implemented yet.
fujay
Post by fujay »
Ah, so it's a limitation. Thanks for the info; I can rest a bit easier now :)
