Installation failed on Ubuntu 16.04
Posted: Mon Sep 04, 2017 5:54 pm
I tried to install Zoneminder with the guide provided here:https://wiki.zoneminder.com/Ubuntu_Serv ... e_easy_way
It works until "apt install zoneminder" with failes with:
It is a clean installation of Ubuntu 16.04 especial for Zoneminder.
I used the PPA: ppa:iconnor/zoneminder
Any clue what is going wrong here?
# apt install zoneminder
Reading package lists... Done
Building dependency tree
Reading state information... Done
Suggested packages:
fcgiwrap
The following NEW packages will be installed:
zoneminder
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/5801 kB of archives.
After this operation, 36.5 MB of additional disk space will be used.
Selecting previously unselected package zoneminder.
(Reading database ... 101476 files and directories currently installed.)
Preparing to unpack .../zoneminder_1.30.4-xenial1_amd64.deb ...
Unpacking zoneminder (1.30.4-xenial1) ...
Processing triggers for systemd (229-4ubuntu19) ...
Processing triggers for ureadahead (0.100.0-19) ...
Processing triggers for man-db (2.7.5-1) ...
Setting up zoneminder (1.30.4-xenial1) ...
ERROR 1819 (HY000) at line 562: Your password does not satisfy the current policy requirements
dpkg: error processing package zoneminder (--configure):
subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
zoneminder
E: Sub-process /usr/bin/dpkg returned an error code (1)
