reinstalled apache, now its broken.
pellle87
Post by pellle87 »
I had some issues with apache so i decided to reinstall it on my debian machine.
I have enabled cgi etc but i cant get the cameras working, i did nothing to the zm install
errors:
2017-08-10 13:23:37.478673	web_js		2064	ERR	getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-761998s.sock ) failed: No such file or directory - checkStreamForErrors()	?view=watch
2017-08-10 13:23:37.449820	web_php		2064	ERR	socket_sendto( /var/run/zm/zms-761998s.sock ) failed: No such file or directory	includes/functions.php	2371
2017-08-10 13:23:49.487037	web_php		1695	ERR	socket_sendto( /var/run/zm/zms-761998s.sock ) failed: No such file or directory	includes/functions.php	2371
Virtualhost that worked before...
<VirtualHost *:80>
  ServerName ****************
        ErrorLog ${APACHE_LOG_DIR}/-error.log
        CustomLog ${APACHE_LOG_DIR}/access.log combined
    <Location />
    Redirect permanent / https://*****************
  </Location>
RewriteEngine on
RewriteCond %{SERVER_NAME} =************************
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
<IfModule mod_ssl.c>
<VirtualHost *:443>
ErrorLog ${APACHE_LOG_DIR}/error.log
        DocumentRoot /usr/share/zoneminder/www/
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
        ServerAlias *******************
        ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
        <Directory "/usr/lib/cgi-bin">
                AllowOverride None
                Order allow,deny
                Allow from all
        </Directory>
SSLCertificateFile /etc/letsencrypt/live/***************/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/*******************/privkey.pem
Include /etc/letsencrypt/options-ssl-apache.conf
</VirtualHost>
</IfModule>
the only files that exsist in /var/run/zm is zmdc.sock and zm.pid
Also i cant login with the ios app, says that credentials are wrong strange enough
any ideas?
Re: reinstalled apache, now its broken.
Force a reinstall. With Debian 8 your database will not be changed. With Debian 9 backup your zm database and restore it once the zoneminder install finishes.
pellle87
Post by pellle87 »
bbunge wrote: Sat Aug 12, 2017 2:23 am Force a reinstall. With Debian 8 your database will not be changed. With Debian 9 backup your zm database and restore it once the zoneminder install finishes.
I did, but still the same problem sadly :/
i even did a apt-get remove, purge and autoremove then reinstalled it
● zoneminder.service - ZoneMinder CCTV recording and surveillance system
   Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled)
   Active: active (running) since Mon 2017-08-14 08:03:20 CEST; 31min ago
 Main PID: 29907 (zmdc.pl)
   CGroup: /system.slice/zoneminder.service
           ├─29907 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
           ├─29936 /usr/bin/zmc -m 1
           ├─29944 /usr/bin/zmc -m 2
           ├─29953 /usr/bin/zmc -m 3
           ├─29958 /usr/bin/perl -wT /usr/bin/zmfilter.pl
           ├─29966 /usr/bin/perl -wT /usr/bin/zmaudit.pl -c
           └─29973 /usr/bin/perl -wT /usr/bin/zmwatch.pl
Aug 14 08:32:01 nas zmc[29944]: INF [Altan: 43000 - Capturing at 25.00 fps]
Aug 14 08:32:01 nas zmc[29953]: INF [Tvattstugan: 43000 - Capturing at 25.00 fps]
Aug 14 08:32:41 nas zmc[29944]: INF [Altan: 44000 - Capturing at 25.00 fps]
Aug 14 08:32:41 nas zmc[29953]: INF [Tvattstugan: 44000 - Capturing at 25.00 fps]
Aug 14 08:33:16 nas zmc[29936]: INF [Garage: 18000 - Capturing at 10.00 fps]
Aug 14 08:33:21 nas zmc[29944]: INF [Altan: 45000 - Capturing at 25.00 fps]
Aug 14 08:33:21 nas zmc[29953]: INF [Tvattstugan: 45000 - Capturing at 25.00 fps]
Aug 14 08:34:01 nas zmc[29944]: INF [Altan: 46000 - Capturing at 25.00 fps]
Aug 14 08:34:01 nas zmc[29953]: INF [Tvattstugan: 46000 - Capturing at 25.00 fps]
Aug 14 08:34:16 nas systemd[1]: Started ZoneMinder CCTV recording and surveillance system.
Still getting the freaking socket error
There is no socket files created in /var/run/zm
pellle87
Post by pellle87 »
what a complete retard i am, a2enconf zoneminder... problem solved
:D
