zoneminder running with failure status
timelyfiasco
Post by timelyfiasco »
Hi, I have another question. Zoneminder suddenly stopped working.
2017-08-05 14:50:14.869078	zma_m1		16184	INF	Monitor-1: 13016 - Closing event 2903, shutting down	zm_monitor.cpp	625
2017-08-05 14:50:14.845582	zma_m2		13264	INF	Monitor-2: 123332 - Closing event 2905, shutting down	zm_monitor.cpp	625
2017-08-05 14:50:14.571243	zma_m2		13264	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-08-05 14:50:14.570994	zma_m1		16184	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-08-05 14:50:14.560588	zmc_dvideo1		13245	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-08-05 14:50:13.501990	zmpkg		16374	INF	Command: stop	zmpkg.pl
2017-08-05 14:50:13.300770	zmpkg		16374	INF	Sanity checking States table...	zmpkg.pl
2017-08-05 14:50:12.332190	zmdc		13160	INF	'zmc -d /dev/video0' crashed, signal 8	zmdc.pl
2017-08-05 14:50:12.121480	zmdc		13160	WAR	'zmc -d /dev/video0' has not stopped at 17/08/05 14:50:12. Sending KILL to pid 16283	zmdc.pl
2017-08-05 14:50:11.081520	zmdc		13160	WAR	'zmc -d /dev/video0' has not stopped at 17/08/05 14:50:11. Sending KILL to pid 16283	zmdc.pl
2017-08-05 14:50:05.080182	zmc_dvideo0		16283	INF	Got signal 15 (Terminated), exiting	zm_signal.cpp	40
2017-08-05 14:50:05.043810	zmdc		13160	INF	'zmc -d /dev/video0' sending stop to pid 16283 at 17/08/05 14:50:05	zmdc.pl
2017-08-05 14:50:04.290450	zmwatch		13303	INF	Restarting capture daemon for Monitor-1, time since last capture 10 seconds (1501915804-1501915794)	zmwatch.pl
2017-08-05 14:50:00.224969	zma_m2		13264	INF	Monitor-2: 123260 - Opening new event 2905, section start	zm_monitor.cpp	1541
2017-08-05 14:50:00.106319	zma_m2		13264	INF	Monitor-2: 123260 - Closing event 2904, section end
I ran sudo systemctl status zoneminder
zoneminder.service - ZoneMinder CCTV recording and surveillance system
   Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Sat 2017-08-05 14:50:15 PHT; 7min ago
  Process: 16374 ExecStop=/usr/bin/zmpkg.pl stop (code=exited, status=1/FAILURE)
  Process: 13126 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=0/SUCCESS)
 Main PID: 13160 (code=exited, status=4)
Aug 05 14:50:14 mutestcctv sudo[16391]: pam_unix(sudo:session): session opened for user www-dat
Aug 05 14:50:14 mutestcctv sudo[16391]: pam_unix(sudo:session): session closed for user www-dat
Aug 05 14:50:14 mutestcctv systemd[1]: zoneminder.service: Control process exited, code=exited
Aug 05 14:50:14 mutestcctv zmc_dvideo1[13245]: INF [Got signal 15 (Terminated), exiting]
Aug 05 14:50:14 mutestcctv zma_m2[13264]: INF [Got signal 15 (Terminated), exiting]
Aug 05 14:50:14 mutestcctv zma_m1[16184]: INF [Got signal 15 (Terminated), exiting]
Aug 05 14:50:14 mutestcctv zma_m2[13264]: INF [Monitor-2: 123332 - Closing event 2905, shutting
Aug 05 14:50:14 mutestcctv zma_m1[16184]: INF [Monitor-1: 13016 - Closing event 2903, shutting
Aug 05 14:50:15 mutestcctv systemd[1]: zoneminder.service: Unit entered failed state.
Aug 05 14:50:15 mutestcctv systemd[1]: zoneminder.service: Failed with result 'exit-code'.
why does it show failure?
I ran
sudo systemctl start zoneminder
sudo systemctl status zoneminder and it shows the following:
   Active: active (running) since Sat 2017-08-05 14:58:03 PHT; 1s ago
  Process: 16688 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=0/SUCCESS)
 Main PID: 16722 (zmdc.pl)
   CGroup: /system.slice/zoneminder.service
           ├─16722 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
           ├─16771 /usr/bin/zmc -d /dev/video0
           ├─16777 /usr/bin/zma -m 1
           ├─16838 /usr/bin/zma -m 2
           ├─16845 /usr/bin/perl -wT /usr/bin/zmfilter.pl
           ├─16860 /usr/bin/perl -wT /usr/bin/zmaudit.pl -c
           ├─16877 /usr/bin/perl -wT /usr/bin/zmwatch.pl
           ├─16895 /usr/bin/perl -w /usr/bin/zmupdate.pl -c
           └─16909 /usr/bin/perl -w /usr/bin/zmtelemetry.pl
Aug 05 14:58:02 mutestcctv zmdc[16722]: INF ['zmupdate.pl -c' starting at 17/08/05 14:58:02, pi
Aug 05 14:58:02 mutestcctv sudo[16885]: pam_unix(sudo:session): session closed for user www-dat
Aug 05 14:58:02 mutestcctv sudo[16901]:     root : TTY=unknown ; PWD=/usr/share/zoneminder/www
Aug 05 14:58:02 mutestcctv sudo[16901]: pam_unix(sudo:session): session opened for user www-dat
Aug 05 14:58:02 mutestcctv zma_m2[16838]: WAR [Waiting for capture daemon]
Aug 05 14:58:03 mutestcctv zmdc[16909]: INF ['zmtelemetry.pl' started at 17/08/05 14:58:03]
there are still errors in the process but zoneminder was running. Can somebody help explain to me what is written?
Re: zoneminder running with failure status
Zoneminder can stop when it runs out of RAM. Your pi may have this issue if you try to run cameras at high resolution, too many cameras and etc.
