Page 1 of 1
Including ZoneMinder livestream in external website
Posted: Fri Jun 30, 2017 5:54 am
by FXZone
is it possible to access the "converted" zoneminder livestream of a camera in an external website?
My cam is a h.264 and is is connected using ffmpg to zoneminder.
I like to use the converted stream, live in the monitor view, in an external website.
Is it possible?
I tried the adress of the stream in the monitor view , without success http://xxx.ccc/zm/cgi-bin/nph-zms?mode= ... yyyyyyyyyy
Any Ideas?
Regards,
FX
Re: Including ZoneMinder livestream in external website
Posted: Fri Jun 30, 2017 12:26 pm
by bbunge
Check the WIKI. This has been covered before!
Posted: Fri Jun 30, 2017 5:19 pm
by FXZone
Thank you for your reply, but i checked the wikihttps://wiki.zoneminder.com/ before and i didn't find anything about this?
Can you give me a tip, which topic contains the solution?
Maybe i am looking at wrong places....
Posted: Fri Jun 30, 2017 5:42 pm
by bbunge
https://wiki.zoneminder.com/How_to_stre ... stallation
From a monitor view right click on the "image" and select view image. Use the URL from that. Just make sure you create an unprivileged user to do this as the user and password is in plain text.
sample code to use as a web page:
<html>
<meta http-equiv="refresh" content="300">
<body>
<p>Backyard</p>
<img src="http://192.168.1.2/zm/cgi-bin/nph-zms?m ... 1486517011">
</body>
</html>
Posted: Fri Jun 30, 2017 8:09 pm
by rockedge
in a WordPress page or post I use something like this: Remember that with certain authorizations set, the URL would be slightly different.
this URL works when :
Options->System->OPT_USE_AUTH = ON
Options->System->AUTH_TYPE = Builtin
Options->System->AUTH_RELAY = NONE
<h2><img class="aligncenter" src="http://your_zm_server/cgi-bin/nph-zms?mode=jpeg&scale=100&maxfps=5&buffer=1000&monitor=1&user=admin" alt="stream down" width="420" height="340" /></h2>
http://rockedge.org/troutcam/
Posted: Sat Jul 01, 2017 6:52 am
by FXZone
Thank you both for your support.
It worked fine for me now.
Posted: Sat Jul 01, 2017 11:50 pm
by rockedge
It can allow others to use the stream URL as is. You must create a user that only has permissions to view a stream. Set this in Options->Users
Another way is to set the AUTH_RELAY = Hashed and set the Options->System->AUTH_HASH_SECRET to something. You can use this something to generate the correct hash to authorize.
I use the first method and create a user like "viewer" and set the permissions to view stream only. So far this has worked for several years ok for me.
