onvif error with Dahua IPC-HFW1420SP
bop480
Post by bop480 »
I'm using Ubuntu server 16.04 with zm 1.30.2 and I try to connect a Dahua IPD-HFW1420SP ip camera.
I click on "add new monitor" then on "ONVIF" then select my camera in the listbox "detected cameras", type username + password then clic next and obtain an error message :
Unable to probe network cameras, status is '255'. Output was:<br/><br/> ERror cannot add_IPFilter<br/>ERror cannot add_ZeroConfiguration<br/>ERror cannot add_IPVersion6<br/>ERror cannot add_DynDNS<br/>ERror cannot add_Extension<br/>ERror cannot add_DiscoveryResolve<br/>ERror cannot add_DiscoveryBye<br/>ERror cannot add_RemoteDiscovery<br/>ERror cannot add_SystemBackup<br/>ERror cannot add_SystemLogging<br/>ERror cannot add_FirmwareUpgrade<br/>ERror cannot add_SupportedVersions<br/>ERror cannot add_SupportedVersions<br/>ERror cannot add_SupportedVersions<br/>ERror cannot add_SupportedVersions<br/>ERror cannot add_SupportedVersions<br/>ERror cannot add_Extension<br/>ERror cannot add_TLS1__1<br/>ERror cannot add_TLS1__2<br/>ERror cannot add_OnboardKeyGeneration<br/>ERror cannot add_AccessPolicyConfig<br/>ERror cannot add_X__509Token<br/>ERror cannot add_SAMLToken<br/>ERror cannot add_KerberosToken<br/>ERror cannot add_RELToken<br/>ERror cannot add_Extension<br/>Nothing returned ffrom get_PTZ<br/><br/> Please the following command from a command line for more information:<br/><br/>/usr/bin/zmonvif-probe.pl profiles http://xxx.xxx.xxx.xxx/onvif/device_service 1.1 user_xxx password_xxx
Running the command in the shell brings following message :
I have no idea what I did wrong...
Can anybody help me?
