Sunluxy image stopping
pyriul27
Post by pyriul27 »
hey all thanks to any that read this and more so to those that can help.)
description of issue camera shows up green in monitor - image appears with time stamp on original image and can be seen changing for 5 seconds then the image stops streaming pauses and jumps ahead a load of frames continues in loop eventually freezing.
i have a sunluxy h.264 base unit with analogue cameras capturing at d1 qaulity, the dvr unit streams to the network via 192.168.50.69:8091-my vm machine is on 192.168.1.110 with a bridged adapter.
monitor settings work as libvlc only - and 704*576 resolution address ( http://192.168.50.69:8091/cgi-bin/view.cgi?chn=1 ) attached is image of errors in log
log file
log file
tried for days to fix built and destroyed like 12 vmachine in hope, the base unit is old got in 2013 but software is junk. also vlc player on network stream has the same issue on my main pc.
i normally view these camera by my browser with a adobe plugin.
thanks for reading this far guys/gals appreciate any input.
