D-Link DCS-942 Question
DJJames
Post by DJJames »
Can not get the above cam working with ZM current version. The cam is connected to the router and shows an image in 192.168.1.65 as well as sending video clips and jpeg's via e-mail but I can't get it to activate in ZM (works in D-link web browser page only). I have the settings as "remote" plus I have follwed the wiki config for IP addy password etc etc but still no registration / image in zm. The cam shows on my network system as there as well. I'm sure it's a path issue or some thing like that which I'm doing wrong but I've tried every combination I can think of in setup both on the cam side and zm side but still no joy. Any thoughts? Years ago I had the same cam set up in ZM so I know it's worked in the past. Thank-you.
Re: D-Link DCS-942 Question
Look at the logs. They will often tell you things. It's why they exist.
DJJames
Post by DJJames »
Thanx for the wiki info but as mentioned i went through that used the input they sugest and still nothing. Here's the log output. Not sure if it says anything helpful.
2017-04-13 17:05:27.374370 zmdc 23354 ERR 'zmc -d /dev/video0' exited abnormally, exit status 255 zmdc.pl
2017-04-13 17:05:27.316794 zmc_dvideo0 32724 ERR No monitors found zmc.cpp 246
2017-04-13 17:05:27.288480 zmdc 23354 ERR 'zmc -d 192.168.1.65' exited abnormally, exit status 255 zmdc.pl
2017-04-13 17:05:27.211620 zmdc 32724 INF 'zmc -d /dev/video0' started at 17/04/13 17:05:27 zmdc.pl
2017-04-13 17:05:27.211380 zmdc 23354 INF 'zmc -d /dev/video0' starting at 17/04/13 17:05:27, pid = 32724 zmdc.pl
2017-04-13 17:05:27.183654 zmc_d192_168_1_65 32723 ERR No monitors found zmc.cpp 246
2017-04-13 17:05:27.121430 zmdc 23354 INF Starting pending process, zmc -d /dev/video0 zmdc.pl
2017-04-13 17:05:27.081210 zmdc 32723 INF 'zmc -d 192.168.1.65' started at 17/04/13 17:05:27 zmdc.pl
2017-04-13 17:05:27.081070 zmdc 23354 INF 'zmc -d 192.168.1.65' starting at 17/04/13 17:05:27, pid = 32723 zmdc.pl
2017-04-13 17:05:27.034340 zmdc 23354 INF Starting pending process, zmc -d 192.168.1.65
You have configured it as a local camera, not as a remote camera.
