Autotracking
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
thecatman
Autotracking
Post by thecatman »
Hi!
It would be fantastic to have an autotracking feature like professional ipcam.
Thanks.
Re: Autotracking
zm does have this feature. Not sure how well it works.
thecatman
Re: Autotracking
Post by thecatman »
sorry! i'm new on linux and zm. i buy 3 Foscam FI9928P and i try to setup they. i'm reading a lot of "how-to"!
itsystemmasters
Re: Autotracking
Post by itsystemmasters »
How did you configure FI9928P in zoneminder? I have bought this model and tried setup it in zoneminder (ver. 1.30.2) and it wasn't working.
My config:
Source type: ffmpeg
Source path: rtsp://myuser:mypasswd@192.168.1.225:88/videoMain
Remote Method: TCP
Options: <nothing>
Target colorspace: 32 bits
Width: 1920
Height: 1080
If I use url in VLC it's working, but in zonemider no.
Please help me!
Re: Autotracking
That looks correct to me. You will need to look in the logs. Do you have enough ram? That resolution will use up a lot of /dev/shm.
itsystemmasters
Re: Autotracking
Thanks a lot for answer. Yesterday, I found issue, my password contained ! symbol and it was problem. After password changing it is working fine. Also, I am able to control PTZ, but track motion isn't working. I have checked Track motion in Control tab, but camera didn't move (rotate). My config in attach.
