Filter to convert Events to h264 video and save to custom location
Justru
Post by Justru » Fri Mar 31, 2017 2:30 pm
Since ZoneMinder saves events as JPG pictures taking a lot of disk space, I came up with a filter to automatically convert old events to H264 video files, move them to a custom location (another disk) and delete the original JPG events.
The solution is for ZoneMinder 1.30.0 and only needs 2 lines of code modification in the original ZM Event.pm file (to save videos with date in the name) and a small bash script to move the files. The idea is based on the post by MartinBty that was updated and improved for current ZM version.
The filter screenshot is below. To make it work, follow my guide.
ArchiveVideo filter
1. Edit original Event.pm file (mine is located in /usr/share/perl5/ZoneMinder directory).
Find the following piece of code, add one line and change one line as shown below.
Original code
        elsif ( $size )
                my $file_size = 'S'.$size;
                push( @file_parts, $file_size );
       my $video_file = "$video_name-".$file_parts[0]."-".$file_parts[1].".$format";
        if ( $overwrite || !-s $video_file )
                Info( "Creating video file $video_file for event $self->{Id}\n" );
Modified code
        elsif ( $size )
        ( my $video_starttime = $self->{StartTime} ) =~ s/\D//g;     # new line
        my $video_file = "$video_name-".$video_starttime."-".ceil($self->{FullLength})."sec.$format";   # modified line
2. Create a new bash script file movevideo.sh with the following content and put it in web server accessible directory. I put mine in /usr/share/zoneminder/www/tools/movevideo.sh
The script below will move the videos to /archive/video directory with dates sub-directories. Make sure it exists and has write permissions for web server user.
user@server:/$ cat /usr/share/zoneminder/www/tools/movevideo.sh
#!/bin/bash
LOG=/var/log/zm/movevideo.log
EXT=mp4
if [ "$1" != "" ]
then
    for i in $(ls $1/*.$EXT)
    do
        DEST=$(sed 's/[^0-9]\+[0-9]/\/archive\/video/' <<< $1)
        DEST=${DEST:0:-8}
        echo  "`date '+%F %T'` Moving from $i to $DEST" >> $LOG
        mkdir -p $DEST
        mv -n $i $DEST >> $LOG 2>&1
    done
else
    echo  "`date '+%F %T'` ERROR: No input provided" >> $LOG
    echo "ERROR: No input provided"
    exit 1
fi
3. Make sure your ZoneMinder options are the following:
OPT_FFMPEG: checked
PATH_FFMPEG: /usr/bin/avconv (or ffmpeg location)
FFMPEG_OUTPUT_OPTIONS: -c:v h264 -crf 18 (this creates high quality h264 video)
FFMPEG_FORMATS: mpg mpeg wmv asf avi mp4* mov swf 3gp** (mp4 is added and checked as default).
4. Finally, create a new ZoneMinder filter that will find old events, convert them to H264 video, move to your custom location (/archive/video in my case):
Filter name: ArchiveVideo (background)
Disk percent: greater than or equal to 90
and Date: less than -3 months
Create video for all matches: checked
Execute command on all matches: /usr/share/zoneminder/www/tools/movevideo.sh
Delete all matches: checked
Save your filter and watch logs how it works!
trumee
Re: Filter to convert Events to h264 video and save to custom location
Post by trumee » Sat Jul 14, 2018 6:19 pm
I had to do following change in movevideo script otherwise all the events were getting put in video directory.
 DEST=$(sed 's/[^0-9]\+/\/archive\/video/' <<< $1)
david786
Post by david786 » Tue Aug 07, 2018 10:58 am
Hi i am getting following error
zmfilter		1029	ERR	Command '/usr/share/zoneminder/www/tools/movevideo.sh /usr/share/zoneminder/www/events/1/18/08/07/15/49/31' exited with status: 72057594037927935	zmfilter.pl
i edit Ext=avi as video saved as avi format
Justru
Post by Justru » Mon Aug 13, 2018 9:13 pm
EXT=avi is case sensitive
Also make sure you set ZM option according your format like below
FFMPEG_FORMATS: mpg mpeg wmv asf avi* mov swf 3gp**
You can also check the log for the issue root cause
mavi
Post by mavi » Fri Sep 28, 2018 10:08 pm
Exactly what I was looking for thanks!
trumee
Post by trumee » Sun Oct 07, 2018 2:54 pm
Anybody tried this on ZM-1.32?
alabamatoy
Post by alabamatoy » Wed Nov 28, 2018 2:16 pm
What does this do to CPU load?
I haven't tried this, but it certainly looks more efficient, simpler and easier to manage than my horrible asynchronous ffmpeg cron ugliness!
