x265-libs conflict
Posted: Tue Mar 21, 2017 8:47 am
I read the post about zmrepo now using ffmpeg from rpmfusion. However, I have a conflict between scrpms and zmrepo over the x265-libs package. Would it solve the problem I if created a new package, using fpm, that provided both shared objects--lib265.so.110 from scrpms and lib265.so.79 from zmrepo? Or would I be better off building ZoneMinder without the H.265 support? None of my cameras use it.
This is Zoneminder 1.30 on CentOS 7.
--> Running transaction check
---> Package ffmpeg-libs.x86_64 0:2.8.11-1.el7 will be installed
--> Processing Dependency: libx265.so.79()(64bit) for package: ffmpeg-libs-2.8.11-1.el7.x86_64
---> Package vo-amrwbenc.x86_64 0:0.1.3-1.el7 will be installed
--> Finished Dependency Resolution
Error: Package: ffmpeg-libs-2.8.11-1.el7.x86_64 (zmrepo)
Requires: libx265.so.79()(64bit)
Available: x265-libs-1.9-3.el7.x86_64 (zmrepo)
Installed: x265-libs-2.3-1.el7.x86_64 (@scrpms)
~libx265.so.110()(64bit)
Available: x265-libs-1.8-1.el7.centos.x86_64 (zmrepo)
~libx265.so.68()(64bit)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
