LiveCD Puppy Linux ZM 1.30.2
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
Post by rockedge » Mon Mar 06, 2017 1:35 pm
UPDATE
Puppy Linux Tahr 6.0.5 operating system.
ZoneMinder has been upgraded from 1.30.1 to 130.2
Complete OS and working ZoneMinder as a LiveCD or install to USB drive or hard drive.
Download Link > https://drive.google.com/open?id=0By2RU ... 181VlJDRzQ
Download and burn to CD or install to HDD or USB drive. Zoneminder will run on boot...WAIT 2-3 minutes for the servers to start.
IMPORTANT --- ON FIRST RUN after installation, Let ZoneMinder start up. Then open a terminal and enter->
#zoneminder stop
#killall mysqld
#mysqld
close the terminal. Open a new terminal and
#zoneminder start
this is to ensure the MySQL server is on the correct Time. and event Export and Video generation and Stills view work.
Download link :[url=https://drive.google.com/open?id=0By2RU ... 181VlJDRzQ[/url]
in a browser http://localhost/zm
Runs completely in RAM as a LiveCD when burned to cd. Can be frugaly or full installed to HDD or USB drive. Use a save folder/file to save all settings in the frugal or RAM mode. Works well installed to USB.
ZoneMinder 1.30.2
Apache 2.4.7 (Ubuntu)
MySQL 5.5.35-1ubuntu1 - (Ubuntu)
PHP extension: mysql, curl, mbstring
PHP version: 5.5.9-1ubuntu4
phpmyadmin 4.6.5.2
phpmyadmin user = root
password = admin
change samba password
#smbpasswd -a root
All other passwords are "admin" or "woofwoof"
Good Luck!
illki
Re: LiveCD Puppy Linux ZM 1.30.2
Post by illki » Thu Jun 22, 2017 8:18 am
hi,
while booting from usb drive i got the following error
puppy_tahr_6.0.5.sts not found. Dropping out to initial-ramdisk console
i can see the file on the usb disk
tried burning iso with lilo, rufus, unetbootin, uneversal USB installer and so on
tried googling also but cannot find the solution that i can apply to this iso
can you help with this error?
Post by rockedge » Mon Jun 26, 2017 1:11 pm
Hello! I will look to see what is going on. can you burn a cd? just as reference as we see what is going wrong. I will test out a usb install again to get warmed up to solve this for you
kevaryza
Post by kevaryza » Fri Jun 30, 2017 4:25 am
Hello rockedge nice job, I could see everything was working very good but I got the following message when I tried to watch a new monitor: you have no permission to access dev/video0 or something like that, I appreciate your job and answer
greetings from Colombia
Kevin
Post by rockedge » Sun Jul 02, 2017 4:26 am
change the permission on the camera like this:
open a console (terminal) and type ->
#chown www-data /dev/video*
or
#chown www-data /dev/video0
then open the monitor setup editor and save the camera setup again. This should fix it.
if you are interested you can update zoneminder from 1.30.2 to 1.30.4
I could give you a set of instructions to do it using the Puppy Package Manager. Takes a few minutes and several commands to change some permissions so they are correct.
illki
Post by illki » Wed Jul 05, 2017 12:22 pm
I will try to get usb cd drive and will reply here later
thanks
Post by rockedge » Thu Jul 06, 2017 12:13 pm
yes! let me know how it works for you. :D
mavi
Post by mavi » Tue Nov 07, 2017 5:08 pm
Thanks for putting this up, will give it a shot.
Users browsing this forum: No registered users and 0 guests
