ZM ends up stopping - Log spam Monitor-x: Capturing at y
Posted: Wed Feb 15, 2017 8:05 pm
Version 1.30.0
Ubuntu 16.04
Installed with the easy way. Was working previously
Reinstalled entire machine, installed easy way again.
Set three cameras to monitor just to test, their FPS is set to 15 in the firmware. All monitors are in RTSP, FFMPEG, 32 bitrate, 1280x720 resolution (just cause it was default for camera firmware)
Amcrest IP 722 bullet WLAN cameras wirelessly connected to dedicated IPs on the router which is Netgear
Monitors seem to work fine I can watch video.
If I leave for any length of time there are some warnings which I interpret as wifi hiccups.
When I come back from work ZM is Stopped and the last of the log is
This FILLS the log
Latest errors to this log
Latest warnings to this log
Any help or ideas appreciated. Have not reinstalled ZM yet that's probably in the works.
Ubuntu 16.04
2017-02-15 14:05:43.397524 zmc_m3 10915 INF Monitor-3: 408000 - Capturing at 14.93 fps zm_monitor.cpp 3116
2017-02-15 14:05:12.480802 zmc_m1 10922 INF Monitor-1: 874000 - Capturing at 14.93 fps zm_monitor.cpp 3116
2017-02-15 14:04:36.840306 zmc_m3 10915 INF Monitor-3: 407000 - Capturing at 15.15 fps zm_monitor.cpp 3116
2017-02-15 14:04:05.923997 zmc_m1 10922 INF Monitor-1: 873000 - Capturing at 15.15 fps zm_monitor.cpp 3116
2017-02-15 14:03:30.293753 zmc_m3 10915 INF Monitor-3: 406000 - Capturing at 14.93 fps zm_monitor.cpp 3116
2017-02-15 14:02:59.370918 zmc_m1 10922 INF Monitor-1: 872000 - Capturing at 14.93 fps zm_monitor.cpp 3116
2017-02-15 14:02:23.718903 zmc_m3 10915 INF Monitor-3: 405000 - Capturing at 14.93 fps zm_monitor.cpp 3116
2017-02-15 14:01:52.825664 zmc_m1 10922 INF Monitor-1: 871000 - Capturing at 15.15 fps zm_monitor.cpp 3116
2017-02-15 14:01:16.133176 zmc_m3 10915 INF Monitor-3: 404000 - Capturing at 14.93 fps zm_monitor.cpp 3116
2017-02-15 14:00:46.315671 zmc_m1 10922 INF Monitor-1: 870000 - Capturing at 14.93 fps zm_monitor.cpp 3116
2017-02-15 14:00:09.535428 zmc_m3 10915 INF Monitor-3: 403000 - Capturing at 14.93 fps zm_monitor.cpp 3116
2017-02-15 13:59:39.730889 zmc_m1 10922 INF Monitor-1: 869000 - Capturing at 15.15 fps zm_monitor.cpp 3116
2017-02-15 13:59:02.969154 zmc_m3 10915 INF Monitor-3: 402000 - Capturing at 15.15 fps zm_monitor.cpp 3116
2017-02-15 13:58:33.207244 zmc_m1 10922 INF Monitor-1: 868000 - Capturing at 14.93 fps zm_monitor.cpp 3116
2017-02-15 13:57:56.454504 zmc_m3 10915 INF Monitor-3: 401000 - Capturing at 14.93 fps zm_monitor.cpp 3116
2017-02-15 13:57:26.629943 zmc_m1 10922 INF Monitor-1: 867000 - Capturing at 15.15 fps zm_monitor.cpp 3116
2017-02-15 13:56:49.903061 zmc_m3 10915 INF Monitor-3: 400000 - Capturing at 15.15 fps zm_monitor.cpp 3116
2017-02-15 13:56:20.065463 zmc_m1 10922 INF Monitor-1: 866000 - Capturing at 14.93 fps zm_monitor.cpp 3116
2017-02-15 13:55:43.419841 zmc_m3 10915 INF Monitor-3: 399000 - Capturing at 17.24 fps zm_monitor.cpp 3116
2017-02-15 13:55:13.511191 zmc_m1 10922 INF Monitor-1: 865000 - Capturing at 14.93 fps zm_monitor.cpp 3116
2017-02-15 13:54:45.243463 zmc_m3 10915 INF Monitor-3: 398000 - Capturing at 14.93 fps zm_monitor.cpp 3116
2017-02-15 13:54:06.974588 zmc_m1 10922 INF Monitor-1: 864000 - Capturing at 15.15 fps zm_monitor.cpp 3116
2017-02-15 13:53:38.699561 zmc_m3 10915 INF Monitor-3: 397000 - Capturing at 15.15 fps zm_monitor.cpp 3116
2017-02-15 13:53:00.431776 zmc_m1 10922 INF Monitor-1: 863000 - Capturing at 14.93 fps zm_monitor.cpp 3116
2017-02-15 13:52:32.115223 zmc_m3 10915 INF Monitor-3: 396000 - Capturing at 14.93 fps zm_monitor.cpp 3116
2017-02-15 13:51:53.844982 zmc_m1 10922 INF Monitor-1: 862000 - Capturing at 15.15 fps zm_monitor.cpp 3116
2017-02-15 13:51:25.547453 zmc_m3 10915 INF Monitor-3: 395000 - Capturing at 15.15 fps zm_monitor.cpp 3116
This FILLS the log
2017-02-15 06:37:28.110326 zmc_m3 10915 ERR Unable to open input rtsp://admin:614EC94F4EE5@192.168.1.22:554/cam/realmonitor?channel=1&subtype=0 due to: Operation not supported zm_ffmpeg_camera.cpp 280
2017-02-15 06:37:28.087359 zmc_m3 10915 ERR Open video took more than 10 seconds. zm_ffmpeg_camera.cpp 452
2017-02-14 21:53:21.655650 zmdc 10889 ERR 'zmc -m 3' exited abnormally, exit status 255 zmdc.pl
2017-02-14 21:53:21.367050 zmdc 10889 ERR 'zmc -m 2' exited abnormally, exit status 255 zmdc.pl
2017-02-14 21:53:21.009950 zmdc 10889 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
2017-02-15 06:37:28.135576 zmc_m3 10921 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2017-02-15 06:37:17.193427 zmc_m3 10915 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2017-02-14 22:07:14.151557 web_php 3114 WAR Login denied for user "Admin" /usr/share/zoneminder/www/includes/functions.php 59
2017-02-14 21:53:22.114760 zmc_m3 10936 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp 267
2017-02-14 21:53:21.821758 zmc_m2 10929 WAR Unable to parse ffmpeg option 0 '', expecting key=value zm_ffmpeg_camera.cpp
