ONVIF Control Script for Reolink Cameras With Authentication
TheSwert
Post by TheSwert » Fri Jan 20, 2017 1:47 am
Hello all,
After looking at the work on the Netcat script, I decided I wanted to make it work with my Reolink RLC-423 and RLC-411 cameras. One of the first challenges was that the Reolink cameras required authentication. The second was that I didn't actually know Perl......
After spending some time with Wireshark, and some documentation on the ONVIF authentication protocol, I was able to get something working.
Inspiration was also taken from viewtopic.php?f=9&t=25442 for the control address parsing.
A couple items of note:
1. I had to include MIME::Base64, Digest::SHA, and DateTime as dependencies for making authentication work
2. Reolink seems to like their presets in 3 digit form
# ZoneMinder Reolink IP Control Protocol Module, Date: 2016-01-19
# Converted for use with Reolink IP Camera by Chris Swertfeger
# Copyright (C) 2016 Chris Swertfeger
# This module contains the first implementation of the Reolink IP camera control
# protocol
package ZoneMinder::Control::Reolink;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
our %CamParams = ();
# Reolink IP Control Protocol
# This script sends ONVIF compliant commands and may work with other cameras
# that require authentication
# The script was developed against a RLC-423 and RLC-411.
# Basic preset functions are supported, but more advanced features, which make
# use of abnormally high preset numbers (ir lamp control, tours, pan speed, etc)
# may or may not work.
# On ControlAddress use the format :
#   USERNAME:PASSWORD@ADDRESS:PORT
#   eg : admin:pass@10.1.2.1:8899
#        admin:password@10.0.100.1:8899
# Use port 8000 by default for Reolink cameras
# Make sure and place a value in the Auto Stop Timeout field.
# Recommend starting with a value of 1 second, and adjust accordingly.
use Time::HiRes qw( usleep );
use MIME::Base64;
use Digest::SHA;
use DateTime;
my ($username,$password,$host,$port);
sub new
    my $class = shift;
    my $id = shift;
    my $logindetails = "";
    bless( $self, $class );
    srand( time() );
    return $self;
our $AUTOLOAD;
sub AUTOLOAD
    my $self = shift;
    my $class = ref( ) || croak( "$self not object" );
    my $name = $AUTOLOAD;
    $name =~ s/.*://;
    if ( exists($self->{$name}) )
        return( $self->{$name} );
sub open
    my $self = shift;
    $self->loadMonitor();
    # Extract the username/password host/port from ControlAddress
    if( $self->{Monitor}{ControlAddress} =~ /^([^:]+):([^@]+)@(.+)/ )
    { # user:pass@host...
      $username = $1;
      $password = $2;
      $host = $3;
    elsif( $self->{Monitor}{ControlAddress} =~ /^([^@]+)@(.+)/ )
    { # user@host...
      $username = $1;
      $host = $2;
    else { # Just a host
      $host = $self->{Monitor}{ControlAddress};
    # Check if it is a host and port or just a host
    if( $host =~ /([^:]+):(.+)/ )
      $host = $1;
      $port = $2;
    else
      $port = 80;
    use LWP::UserAgent;
    $self->{ua}->agent( "ZoneMinder Control Agent/".ZoneMinder::Base::ZM_VERSION );
    $self->{state} = 'open';
sub close
    my $self = shift;
    $self->{state} = 'closed';
sub printMsg
    my $self = shift;
    my $msg = shift;
    my $msg_len = length($msg);
sub sendCmd
    my $self = shift;
    my $cmd = shift;
    my $msg = shift;
    my $content_type = shift;
    my $result = undef;
    printMsg( $cmd, "Tx" );
    my $server_endpoint = "http://".$host.":".$port."/$cmd";
    my $req = HTTP::Request->new( POST => $server_endpoint );
    $req->header('content-type' => $content_type);
    $req->header('Host' => $host.":".$port);
    $req->header('content-length' => length($msg));
    $req->header('accept-encoding' => 'gzip, deflate');
    $req->header('connection' => 'close');
    $req->content($msg);
    if ( $res->is_success ) {
        $result = !undef;
    } else {
        Error( "After sending PTZ command, camera returned the following error:'".$res->status_line()."'" );
    return( $result );
sub getCamParams
    my $self = shift;
    my $nonce;
    for (0..20){$nonce .= chr(int(rand(254)));}
    my $mydate = DateTime->now()->iso8601().'Z';
    my $sha = Digest::SHA->new(1);
    $sha->add($nonce.$mydate.$password);
    my $digest = encode_base64($sha->digest,"");
    my $msg = '<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><GetImagingSettings xmlns="http://www.onvif.org/ver20/imaging/wsdl"><VideoSourceToken>000</VideoSourceToken></GetImagingSettings></s:Body></s:Envelope>';
    my $server_endpoint = "http://".$self->{Monitor}->{ControlAddress}."/onvif/imaging";
    $req->header('content-type' => 'application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver20/imaging/wsdl/GetImagingSettings"');
    $req->header('connection' => 'Close');
        # We should really use an xml or soap library to parse the xml tags
        my $content = $res->decoded_content;
        if ($content =~ /.*<tt:(Brightness)>(.+)<\/tt:Brightness>.*/) {
            $CamParams{$1} = $2;
        if ($content =~ /.*<tt:(Contrast)>(.+)<\/tt:Contrast>.*/) {
    else
        Error( "Unable to retrieve camera image settings:'".$res->status_line()."'" );
#autoStop
#This makes use of the ZoneMinder Auto Stop Timeout on the Control Tab
sub autoStop
    my $self = shift;
    my $autostop = shift;
    if( $autostop ) {
        Debug( "Auto Stop" );
        my $cmd = 'onvif/PTZ';
        my $nonce;
        my $msg = '<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><Stop xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><PanTilt>true</PanTilt><Zoom>false</Zoom></Stop></s:Body></s:Envelope>';
        my $content_type = 'application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver20/ptz/wsdl/ContinuousMove"';
        usleep( $autostop );
        $self->sendCmd( $cmd, $msg, $content_type );
# Reset the Camera
sub reset
    Debug( "Camera Reset" );
    my $self = shift;
    my $nonce;
    my $cmd = "";
    my $msg = '<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><SystemReboot xmlns="http://www.onvif.org/ver10/device/wsdl"/></s:Body></s:Envelope>';
    my $content_type = 'application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver10/device/wsdl/SystemReboot"';
#Up Arrow
sub moveConUp
    Debug( "Move Up" );
    my $self = shift;
    my $nonce;
    my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><PanTilt x="0" y="0.5" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
    $self->autoStop( $self->{Monitor}->{AutoStopTimeout} );
#Down Arrow
sub moveConDown
    Debug( "Move Down" );
    my $self = shift;
    my $nonce;
    my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><PanTilt x="0" y="-0.5" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
#Left Arrow
sub moveConLeft
    Debug( "Move Left" );
    my $self = shift;
    my $nonce;
    my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><PanTilt x="-0.49" y="0" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
#Right Arrow
sub moveConRight
    Debug( "Move Right" );
    my $self = shift;
    my $nonce;
     my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><PanTilt x="0.49" y="0" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
#Zoom In
sub zoomConTele
    Debug( "Zoom Tele" );
    my $self = shift;
    my $nonce;
    my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><Zoom x="0.49" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
#Zoom Out
sub zoomConWide
    Debug( "Zoom Wide" );
    my $self = shift;
    my $nonce;
    my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><Zoom x="-0.49" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
#Diagonally Up Right Arrow
#This camera does not have builtin diagonal commands so we emulate them
sub moveConUpRight
    my $self = shift;
    my $nonce;
    my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><PanTilt x="0.5" y="0.5" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
#Diagonally Down Right Arrow
sub moveConDownRight
    my $self = shift;
    my $nonce;
    my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><PanTilt x="0.5" y="-0.5" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
#Diagonally Up Left Arrow
sub moveConUpLeft
    my $self = shift;
    my $nonce;
    my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><PanTilt x="-0.5" y="0.5" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
#Diagonally Down Left Arrow
sub moveConDownLeft
    my $self = shift;
    my $nonce;
    my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><Velocity><PanTilt x="-0.5" y="-0.5" xmlns="http://www.onvif.org/ver10/schema"/></Velocity></ContinuousMove></s:Body></s:Envelope>';
#Stop
sub moveStop
    Debug( "Move Stop" );
    my $self = shift;
    my $nonce;
    my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><Stop xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><PanTilt>true</PanTilt><Zoom>false</Zoom></Stop></s:Body></s:Envelope>';
#Set Camera Preset
sub presetSet
    my $self = shift;
    my $params = shift;
    my $nonce;
    my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><SetPreset xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><PresetToken>'.$preset.'</PresetToken></SetPreset></s:Body></s:Envelope>';
    my $content_type = 'application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver20/ptz/wsdl/SetPreset"';
#Recall Camera Preset
sub presetGoto
    my $self = shift;
    my $params = shift;
    my $num = sprintf("%03d", $preset);
    $num=~ tr/ /0/;
    my $nonce;
     my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><GotoPreset xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>000</ProfileToken><PresetToken>'.$num.'</PresetToken></GotoPreset></s:Body></s:Envelope>';
    my $content_type = 'application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver20/ptz/wsdl/GotoPreset"';
#Horizontal Patrol
#To be determined if this camera supports this feature
sub horizontalPatrol
    Debug( "Horizontal Patrol" );
    my $self = shift;
    my $cmd = '';
    my $msg ='';
    my $content_type = '';
#    $self->sendCmd( $cmd, $msg, $content_type );
    Error( "PTZ Command not implemented in control script." );
#Horizontal Patrol Stop
sub horizontalPatrolStop
    Debug( "Horizontal Patrol Stop" );
    my $self = shift;
    my $cmd = '';
    my $msg ='';
# Increase Brightness
sub irisAbsOpen
    Debug( "Iris $CamParams{'Brightness'}" );
    my $self = shift;
    my $params = shift;
    $self->getCamParams() unless($CamParams{'Brightness'});
    my $step = $self->getParam( $params, 'step' );
    my $max = 100;
    $CamParams{'Brightness'} += $step;
    $CamParams{'Brightness'} = $max if ($CamParams{'Brightness'} > $max);
    my $cmd = 'onvif/imaging';
    my $nonce;
    my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><SetImagingSettings xmlns="http://www.onvif.org/ver20/imaging/wsdl"><VideoSourceToken>000</VideoSourceToken><ImagingSettings><Brightness xmlns="http://www.onvif.org/ver10/schema">'.$CamParams{'Brightness'}.'</Brightness></ImagingSettings><ForcePersistence>true</ForcePersistence></SetImagingSettings></s:Body></s:Envelope>';
    my $content_type = 'application/soap+xml; charset=utf-8; action="http://www.onvif.org/ver20/imaging/wsdl/SetImagingSettings"';
# Decrease Brightness
sub irisAbsClose
    my $self = shift;
    my $params = shift;
    $self->getCamParams() unless($CamParams{'brightness'});
    my $min = 0;
    $CamParams{'Brightness'} -= $step;
    $CamParams{'Brightness'} = $min if ($CamParams{'Brightness'} < $min);
    my $nonce;
# Increase Contrast
sub whiteAbsIn
    Debug( "Iris $CamParams{'Contrast'}" );
    my $self = shift;
    my $params = shift;
    $self->getCamParams() unless($CamParams{'Contrast'});
    my $max = 100;
    $CamParams{'Contrast'} += $step;
    $CamParams{'Contrast'} = $max if ($CamParams{'Contrast'} > $max);
    my $nonce;
    my $msg ='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope"><s:Header><Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd"><UsernameToken><Username>'.$username.'</Username><Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">'.$digest.'</Password><Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary">'.encode_base64($nonce,"").'</Nonce><Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">'.$mydate.'</Created></UsernameToken></Security></s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><SetImagingSettings xmlns="http://www.onvif.org/ver20/imaging/wsdl"><VideoSourceToken>000</VideoSourceToken><ImagingSettings><Contrast xmlns="http://www.onvif.org/ver10/schema">'.$CamParams{'Contrast'}.'</Contrast></ImagingSettings><ForcePersistence>true</ForcePersistence></SetImagingSettings></s:Body></s:Envelope>';
# Decrease Contrast
sub whiteAbsOut
    my $self = shift;
    my $params = shift;
    my $min = 0;
    $CamParams{'Contrast'} -= $step;
    $CamParams{'Contrast'} = $min if ($CamParams{'Contrast'} < $min);
    my $nonce;
1;
Like I mentioned before, I didn't know Perl before embarking on this quest (still don't really :lol: ), so rookie mistakes are probably abound. I welcome any suggestions for improving the script. I haven't tested it out on my RLC-420, but it should work for the features it does support.
xnaron
Re: ONVIF Control Script for Reolink Cameras With Authentication
Post by xnaron » Mon Apr 03, 2017 3:43 pm
I am working on a project to convert pelco-d to onvif on a raspberry pi. The idea is to hook a PTZ pelco-d controller to a raspberry pi via rs485 breakout board and then use onvif over the network to control the RLC-423. Do you have any skeleton perl code you can share that you used to test against the RLC-423 without the zoneminder code?
thanks,
Brendin
TheSwert
Post by TheSwert » Tue Apr 04, 2017 12:18 pm
Not really. All of my testing was around making it work within Zoneminder. You should be able to find some code for sending SOAP requests via perl, or any other language for that matter. The important bits for interfacing with the RLC-423 are the authentication and the autostop. The camera has continuous move, so if you don't send it a stop request, it will keep spinning.
Breaking down the function that moves the camera right.
sub moveConRight
    my $self = shift;
    #Beginning of authentication piece
    my $nonce;
    #End of authentication piece
    #Build the SOAP request that will be sent to the camera
    #Invoke the function that will actually send the SOAP request
    #Send the autostop after a certain amount of time
Please let me know if you have any questions. I'll be happy to help where I can.
Mike0999
Post by Mike0999 » Sun Dec 31, 2017 5:39 pm
Don’t know if anyone has the time to help, but I tried this control script with the RLC-423 and haven’t been able to get it to work. I can use the camera fine through zoneminder otherwise. I can also ptz with their mobile app, as well as iSpy. I am using zm 1.30.4 and put the file, named Reolink.pm, in the /usr/share/perl15/ZoneMinder/Control/ directory. I’m on Ubuntu server 16.04. Everything otherwise working great.
TheSwert
Post by TheSwert » Tue Jan 02, 2018 11:55 pm
Sounds like you put the script in the right place. Did you update the settings in the Control tab for the camera? You have the put in settings in the Control Address field, and it should be in the format of username:password@10.0.100.1:8000. Are you seeing any errors in the log when you try and issue a command to the camera?
vernxx
Post by vernxx » Mon Apr 02, 2018 3:13 pm
Works with the couple of Reolink 423s cameras I have, did lock the machine up a couple of times but not setup and tested fully yet. I can do presets and ptz and If I exit the window by going back to events and then exiting it seems fine. cheers for the good work
speedfixer
Post by speedfixer » Sat Dec 08, 2018 5:20 am
I've tried.
I can't get it to work on my 423.
On the control tab I have:
Controllable <checked>
Control Type Reolink RLC-423
Control Device
Control Address admin:[psswd]@192.168.8.127:8000
Auto Stop Timeout
Track Motion
Track Delay
Return Location
Return Delay
This was a clean install.
6 x Reolink 410
1 x Reolink 423 (ptz)
1 x Sm3C (something - don't remember - it works)
All streams are low - 640 X 320 or so. All are on monitor.
Log is clean -- no errors for long periods
My system:
ASUS M3A78-T AMD Phenom(tm) 9850 Quad-Core Processor 8g ram
Linux rd1 4.15.0-39-generic #42-Ubuntu SMP Tue Oct 23 15:48:01 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
/dev/sda3 88G 4.9G 78G 6% /
/dev/sdb1 687G 73M 652G 1% /mnt/Oak1
tmpfs 3.9G 141M 3.8G 4% /dev/shm
Dual nic: have ZM and HA, cameras on one subnet -- rest of the house on another.
All cams/cam server on static IP.
When I click a control button:
I get a popup, for example:
Control response was status = undefined
message = /usr/bin/zmcontrol.pl --command=movConUpRight --id=12=>
log messages:
2018-12-07 21:10:06 zmc_m14 1773 INF reo_5_low: images:724600 - Capturing at 6.25 fps, capturing bandwidth 14361bytes/sec zm_monitor.cpp 2473
2018-12-07 21:10:05 zmc_m13 1766 INF reo_4_low: images:724900 - Capturing at 5.88 fps, capturing bandwidth 14240bytes/sec zm_monitor.cpp 2473
2018-12-07 21:10:03 zma_m10 1863 INF reo_2_low: 723500 - Analysing at 5.88 fps zm_monitor.cpp 1247
2018-12-07 21:10:01 zmc_m11 1756 INF reo_3_low: images:724600 - Capturing at 5.88 fps, capturing bandwidth 27780bytes/sec zm_monitor.cpp 2473
2018-12-07 21:09:59 web_php 2869 ERR /usr/bin/zmcontrol.pl --command=moveConUpRight --id=12=> /usr/share/zoneminder/www/includes/functions.php 2043
2018-12-07 21:09:58 zmcontrol 2898 INF Starting control server 12/Reolink zmcontrol.pl
2018-12-07 21:09:58 zmcontrol 2898 FAT Can't load ZoneMinder::Control::ReolinkCan't locate DateTime.pm in @INC (you may need to install the DateTime module) (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.26.1 /usr/local/share/perl/5.26.1 /usr/lib/x86_64-linux-gnu/perl5/5.26 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.26 /usr/share/perl/5.26 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at /usr/share/perl5/ZoneMinder/Control/Reolink.pm line 71.BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder/Control/Reolink.pm line 71.Compilation failed in require at /usr/share/perl/5.26/Module/Load.pm line 77.Can't locate ZoneMinder/Control/Reolink in @INC (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.26.1 /usr/local/share/perl/5.26.1 /usr/lib/x86_64-linux-gnu/perl5/5.26 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.26 /usr/share/perl/5.26 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at /usr/share/perl/5.26/Module/Load.pm line 77. zmcontrol.pl
2018-12-07 21:09:56 zmc_m12 2036 INF reo_ptz_low_12: images:300 - Capturing at 7.14 fps, capturing bandwidth 35356bytes/sec zm_monitor.cpp 2473
2018-12-07 21:09:52 zmc_m16 4123 INF svc_1_low: images:9400 - Capturing at 5.88 fps, capturing bandwidth 23664bytes/sec zm_monitor.cpp 2473
2018-12-07 21:09:50 zmc_m14 1773 INF reo_5_low: images:724500 - Capturing at 5.88 fps, capturing bandwidth 13648bytes/sec zm_monitor.cpp 2473
2018-12-07 21:09:50 zmc_m10 1746 INF reo_2_low: images:725100 - Capturing at 6.25 fps, capturing bandwidth 30745bytes/sec zm_monitor.cpp 2473
2018-12-07 21:09:49 zmc_m15 1781 INF reo_6_low: images:724500 - Capturing at 5.88 fps, capturing bandwidth 13356bytes/sec zm_monitor.cpp 2473
What is DateTime.pm?
david
(I also can't get to web site monitor to work, and the API test fails. Each for another thread after this is corrected.)
If you don't try - you lose - automatically.
TheSwert
Post by TheSwert » Sat Dec 08, 2018 2:28 pm
You will need to install the perl module DateTime. That can be accomplished by running the below.
sudo cpanm DateTime
The reason this dependency exists is to handle the proper ISO 8601 formatting of the date when doing the ONVIF authentication. Truthfully, I'm not an expert in perl, so if there's a more elegant way of doing it, I'm all ears. Let me know if installing the module resolves your issue.
Couple other tips:
  • Going by the settings you provided, make sure you populate Auto Stop Timeout or else the camera will spin forever (funny for 5 seconds, then just annoying). I use 0.10 for my timeout.
  • I've had much better luck using the TCP RTMP than the UDP RTSP stream (much less tearing of the image and less dropped frames) for the source in the monitor setup. I've noticed the Reolink cameras can be finicky. See below for what to use for the different streams.
Substream
rtmp://192.168.8.127/bcs/channel0_sub.bcs?channel=0&stream=0&user=admin&password=password
Main stream
rtmp://192.168.8.127/bcs/channel0_main.bcs?channel=0&stream=0&user=admin&password=password
speedfixer
Post by speedfixer » Sat Dec 08, 2018 7:02 pm
Terrific!
Had to install cpanminus - which had DateTime as part of its dependencies.
Now, how can something be bundled together so others don't have this trouble?
david
re: addressing the streams:
It seems there are many ways to talk to these (most?) cameras.
And so many fields that need an address/path (advice?) on how to talk to them.
In some cases (like my next trouble: web site monitor) - a setting in one mode/address type persists and makes a difference when you change that mode/type/something and the field gets hidden (presumed unused by the change) - but those other NOW hidden fields DO make a difference.
Perhaps there could/should a wiki entry just about all the addressing fields and addressing methods relating only to camera access?
Users browsing this forum: No registered users and 0 guests
