Request for help with control scripts
Posted: Fri Dec 09, 2016 4:42 pm
I have looked all over for some details about the interface with camera PTZ control scripts and I cannot seem to find anything which describes the variables being passed between ZM and a specific control script. I am not a competent perl programmer, so I may simply be struggling with the syntax. For example, there appears to be an object in the control script $req which is the http string to be sent to the camera. It has components ($req->uri() for example) and I cannot seem to figure out how to reference the full http command string. I also dont know how to list all of the components of the class $req, so I may be using the totally wrong variable. It appears to be a hash, but I dont seem to understand how to enumerate the hash values. Q: How do I expose the whole string being sent to the camera?
Below is the line of code I'm using to post the response from the camera $res->status_line() and my attempt to show the command string $req in the log stream, but all I get for the $req value is "HASH(0x2d0cf88)" The camera responds "200 OK" every time.
Also, some fiddling with these scripts has led me to the conclusion that if I make a change to the script file, the changed script file is not reread by the system. Apparently, I hafta close the camera monitor display, then disable the monitor (in the console) which uses it, and save that, and then re-enable the monitor and save that, then re-open the specific camera in order for the system to "see" the change made to the script file. Q: Is there an easier way to force a re-read of the control script, instead of this complex process? With my limited knowledge of perl, Im having to trial-and-error this, and its a pain to go through all that for every change to the script file.
Any help from the experts would be appreciated.
Error( "Control command result: '".$res->status_line()."' for URL ".$req );
