Cannot see still images inside bulk frames
Posted: Wed Nov 23, 2016 7:04 pm
I am using 1.29.0 and everything is OK.
I would like to update to 1.30.0 but I found an issue in new 1.30.0.
I am using a Debian Stretch just installed in a virtual machine and a couple of ipcam using Mocord method.
In the event list, click on the "Frames" column you can see the frames list groped by 100, (bulk frames).
If you click on frame id 100 (bulk frame), a new window with picture comes up with the correct image. If you want to go to the next or previous picture clicking "Next" or "Prev" at the bottom of the page, no picture is displayed.
So I can see only the bulk frames, and not the frames inside the bulk. The event streaming is OK.
The error message that appears in apache2 error log file is the following:
Thanks for your help!
[Wed Nov 23 20:02:15.696329 2016] [:error] [pid 29766] [client 192.168.19.106:62769] PHP Notice: Undefined property: Frame::$Id in /usr/share/zoneminder/www/includes/Frame.php on line 73, referer: http://192.168.19.110/zm/index.php?view=frame&eid=283&fid=100
[Wed Nov 23 20:02:15.746156 2016] [:error] [pid 29766] [client 192.168.19.106:62769] ERR [No image path], referer: http://192.168.19.110/zm/index.php?view=frame&eid=283&fid=101&scale=100
