onvif probe not working (camera does not accept default namespace)
laurentmartin
Post by laurentmartin » Sat Sep 24, 2016 6:57 pm
I have an onvif camera (szsinocam SN-IPC-5024CSW).
It works well with zoneminder (1.30, ubuntu, iconnor), in either snapshot or rtsp mode.
I would like to discover the camera with zoneminder.
for instance, I execute:
zmonvif-probe.pl -v probe
-> no detection.
Basically, I tracked it down to the fact that the camera does not accept the xml default namespace in "Action", "Message" and "To" tags in the probe message. Instead it seems to expect the prefix notation.
Is it possible to have zmonvif-probe.pl to use a prefix for the "addressing" namespace, instead of default notation ?
For the time being I fixed my issue by adding:
  $bytes=~s{<([A-Z][a-zA-Z]+ xmlns)(="[^"]+/addressing">[^<]+</)([^>]+>)}{<a:$1:a$2a:$3}g;
just before the line:
  $socket->send($bytes);
in TransportUDP.pm
Laurent
details:
I tried the onvif npm (nodejs) : https://www.npmjs.com/package/onvif
var onvif = require('onvif');
onvif.Discovery.on('device', function(cam){console.log(cam);})
onvif.Discovery.probe();
it works perfect.
I tried also with the following ruby code:
#!/usr/bin/env ruby
require 'socket'
require 'ipaddr'
require 'timeout'
MULTICAST_ADDR = "239.255.255.250"
PORT = 3702
probemsg='<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:a="http://schemas.xmlsoap.org/ws/2004/08/addressing">
  <s:Header>
    <a:Action s:mustUnderstand="1">http://schemas.xmlsoap.org/ws/2005/04/discovery/Probe</a:Action>
    <a:MessageID>urn:uuid:cd376dcb-e7af-8566-7591-4f0158c65ed0</a:MessageID>
    <a:ReplyTo>
      <a:Address>http://schemas.xmlsoap.org/ws/2004/08/addressing/role/anonymous</a:Address>
    </a:ReplyTo>
    <a:To s:mustUnderstand="1">urn:docs-oasis-open-org:ws-dd:ns:discovery:2009:01</a:To>
  </s:Header>
  <s:Body>
    <Probe xmlns="http://schemas.xmlsoap.org/ws/2005/04/discovery">
      <d:Types xmlns:d="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:dp0="http://www.onvif.org/ver10/network/wsdl">dp0:NetworkVideoTransmitter</d:Types>
    </Probe>
  </s:Body>
</s:Envelope>
ip =  IPAddr.new(MULTICAST_ADDR).hton + IPAddr.new("0.0.0.0").hton
sock = UDPSocket.new
sock.setsockopt(Socket::IPPROTO_IP, Socket::IP_ADD_MEMBERSHIP, ip)
#  socket.setsockopt(Socket::IPPROTO_IP, Socket::IP_TTL, [1].pack('i'))
sock.bind(Socket::INADDR_ANY, PORT)
sock.send(probemsg, 0, MULTICAST_ADDR, PORT)
begin
    status = Timeout::timeout(2) {
loop do
  msg, info = sock.recvfrom(1500)
  puts "MSG: #{msg} from #{info[2]} (#{info[3]})/#{info[1]} len #{msg.size}"
end
rescue
end
sock.close
it works perfect.
So, it's either that zmonvif-probe.pl doesnt somehow send a correct message. But as far as I understand, zm sends messages compiled from the official WSDL.
Or that the camera is limited in the type of message it accepts.
The message I see sent from zm is:
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" >
  <SOAP-ENV:Header>
    <Action xmlns="http://schemas.xmlsoap.org/ws/2004/08/addressing">http://schemas.xmlsoap.org/ws/2005/04/discovery/Probe</Action>
    <MessageID xmlns="http://schemas.xmlsoap.org/ws/2004/08/addressing">urn:uuid:05253542-8285-11E6-9555-AA1CD56BB8A0</MessageID>
    <To xmlns="http://schemas.xmlsoap.org/ws/2004/08/addressing">urn:schemas-xmlsoap-org:ws:2005:04:discovery</To>
  </SOAP-ENV:Header>
  <SOAP-ENV:Body>
    <Probe xmlns="http://schemas.xmlsoap.org/ws/2005/04/discovery" xmlns:dn="http://www.onvif.org/ver10/network/wsdl" xmlns:tds="http://www.onvif.org/ver10/device/wsdl">
      <Types>dn:NetworkVideoTransmitter tds:Device</Types>
      <Scopes></Scopes>
    </Probe>
  </SOAP-ENV:Body>
</SOAP-ENV:Envelope>
So, I tried to feed this msg template into the script: does not work (of course), no answer
But if I use the namespace prefix notation for "addressing" tags, it works .. like this:
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://www.w3.org/2003/05/soap-envelope" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:a="http://schemas.xmlsoap.org/ws/2004/08/addressing">
  <SOAP-ENV:Header>
    <a:Action>http://schemas.xmlsoap.org/ws/2005/04/discovery/Probe</Action>
    <a:MessageID>urn:uuid:05253542-8285-11E6-9555-AA1CD56BB8A0</MessageID>
    <a:To>urn:schemas-xmlsoap-org:ws:2005:04:discovery</To>
  </SOAP-ENV:Header>
  <SOAP-ENV:Body>
      <Scopes></Scopes>
    </Probe>
  </SOAP-ENV:Body>
it shows that it is a problem in the camera ...
