Page 1 of 1
Ubuntu 16.04 and Database Errors
Posted: Sun Sep 04, 2016 5:27 pm
by jsylvia007
Howdy all!
My Setup:
Ubuntu 16.04
MySQL - mysqld Ver 5.7.13-0ubuntu0.16.04.2 for Linux on x86_64 ((Ubuntu))
ZoneMinder - 1.30.0
I've been running Zoneminder for years, and I'm now having an issue. The first piece is that I was noticing one of my cameras was recording events that were hours long in Modect... SO I wanted to fix that by changing the AlmRefImageBlendPct to something higher...
When I tried to edit the monitor, I got this:
Can't write log entry 'INSERT INTO Logs ( TimeKey, Component, Pid, Level, Code, Message, File, Line ) values ( ?, ?, ?, ?, ?, ?, ?, ? )': SQLSTATE[22001]: String data, right truncated: 1406 Data too long for column 'Message' at row 1
Additionally, I tried to run zmupdate.pl -f, and that resulted in this:
Freshening configuration in database
Loading config from DB
Saving config to DB
DBD::mysql::st execute failed: Data too long for column 'DefaultValue' at row 1 at /usr/share/perl5/ZoneMinder/Config.pm line 227.
Can't execute: Data too long for column 'DefaultValue' at row 1 at /usr/bin/zmupdate.pl line 343.
Can anyone tell me what's going on? It looks to me like everything is working, but I can't make any changes for some reason.
[SOLVED] Ubuntu 16.04 and Database Errors
Posted: Sun Sep 04, 2016 5:46 pm
by jsylvia007
Note... Read the damn install docs here:
http://zoneminder.readthedocs.io/en/lat ... untu-16-04
I specifically missed this section:
Step 3: Configure MySQL
Note
The MySQL default configuration file (/etc/mysql/mysql.cnf)is read through several symbolic links beginning with /etc/mysql/my.cnf as follows:
/etc/mysql/my.cnf -> /etc/alternatives/my.cnf
/etc/alternatives/my.cnf -> /etc/mysql/mysql.cnf
/etc/mysql/mysql.cnf is a basic file
Certain new defaults in MySQL 5.7 are currently causing some issues with ZoneMinder, the workaround is to modify the sql_mode setting of MySQL.
To better manage the MySQL server it is recommended to copy the sample config file and replace the default my.cnf symbolic link.
rm /etc/mysql/my.cnf  (this removes the current symbolic link)
cp /etc/mysql/mysql.conf.d/mysqld.cnf /etc/mysql/my.cnf
To change MySQL settings:
nano /etc/mysql/my.cnf
All fixed.
