Everything installed without an issue and looked good. Added my cameras (HikVision DS-2CD2332-I turrets). Now these cameras that I've used successfully in the past are not even displaying. I could've sworn that I entered the same setup for the cameras ("rtsp://admin:<password>@192.168.111.101//Streaming/Channels/1") as before, but I might be mistaken.
Setup screenshots and complete log included below.
Help me Obi Wan kenobe, you're my only hope!
Thanks!
Oedipus Rekt
I'm getting some funky errors in my log that I'm not sure how to remedy:
More Clear Refresh Export Close System Log
Updated: Sun 12th Jun, 12:42am State: alert Total: 14141 Available: 14141 Displaying: 200
Filter log - Component Server PID Level File Line Reset
Date/Time
Component Server PID Level Message File Line
2016-06-12 00:42:21.955494 zmc_m3 2656 INF Driveway: 2136000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-12 00:42:08.927417 zmc_m2 24031 INF Front_Door: 11000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:41:15.379133 zmc_m3 2656 INF Driveway: 2135000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:40:28.899899 zmc_m2 24031 INF Front_Door: 10000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:40:08.727129 zmc_m3 2656 INF Driveway: 2134000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-12 00:39:02.146056 zmc_m3 2656 INF Driveway: 2133000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:38:48.919504 zmc_m2 24031 INF Front_Door: 9000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:37:55.556598 zmc_m3 2656 INF Driveway: 2132000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:37:55.258038 web_js 24056 ERR Uncaught TypeError: Cannot read property 'isDisplayed' of undefined http://192.168.159.10/zm/tools/mootools/mootools-more.js 1
2016-06-12 00:37:54.683459 web_js 24056 ERR Uncaught TypeError: Cannot read property 'isDisplayed' of undefined http://192.168.159.10/zm/tools/mootools/mootools-more.js 1
2016-06-12 00:37:53.796840 web_js 24056 ERR Uncaught TypeError: Cannot read property 'isDisplayed' of undefined http://192.168.159.10/zm/tools/mootools/mootools-more.js 1
2016-06-12 00:37:47.805442 web_php 2674 ERR socket_sendto( /var/run/zm/zms-711775s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-06-12 00:37:08.920154 zmc_m2 24031 INF Front_Door: 8000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:36:48.954077 zmc_m3 2656 INF Driveway: 2131000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-12 00:35:42.376877 zmc_m3 2656 INF Driveway: 2130000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:35:28.921552 zmc_m2 24031 INF Front_Door: 7000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:34:35.761637 zmc_m3 2656 INF Driveway: 2129000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-12 00:33:48.904631 zmc_m2 24031 INF Front_Door: 6000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:33:29.165516 zmc_m3 2656 INF Driveway: 2128000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:32:22.560616 zmc_m3 2656 INF Driveway: 2127000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:32:08.907538 zmc_m2 24031 INF Front_Door: 5000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:31:15.963266 zmc_m3 2656 INF Driveway: 2126000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-12 00:30:28.942190 zmc_m2 24031 INF Front_Door: 4000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:30:09.365485 zmc_m3 2656 INF Driveway: 2125000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:29:02.749642 zmc_m3 2656 INF Driveway: 2124000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-12 00:28:48.914856 zmc_m2 24031 INF Front_Door: 3000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:27:56.151372 zmc_m3 2656 INF Driveway: 2123000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:27:08.932324 zmc_m2 24031 INF Front_Door: 2000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:26:49.556378 zmc_m3 2656 INF Driveway: 2122000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:25:42.963179 zmc_m3 2656 INF Driveway: 2121000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-12 00:25:28.947839 zmc_m2 24031 INF Front_Door: 1000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:24:46.992214 web_php 1565 ERR socket_sendto( /var/run/zm/zms-449973s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-06-12 00:24:36.374080 zmc_m3 2656 INF Driveway: 2120000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:23:59.780481 web_js 1590 ERR getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-855974s.sock ) failed: No such file or directory - checkStreamForErrors() ?view=watch
2016-06-12 00:23:59.750216 web_php 1590 ERR socket_sendto( /var/run/zm/zms-855974s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-06-12 00:23:48.328776 zmc_m2 24031 INF Priming capture from rtsp://admin:booger.159@192.168.159.180//Streaming/Channels/1 zm_ffmpeg_camera.cpp 104
2016-06-12 00:23:48.322618 zmc_m2 24031 INF Starting Capture version 1.29.0 zmc.cpp 250
2016-06-12 00:23:48.273870 zmdc 1416 WAR Can't find process with command of 'zma -m 2' zmdc.pl
2016-06-12 00:23:48.225309 undef 24031 INF No Server ID or Name specified in config. Not using Multi-Server Mode. zm_config.cpp 139
2016-06-12 00:23:48.194080 zmdc 24031 INF 'zmc -m 2' started at 16/06/12 00:23:48 zmdc.pl
2016-06-12 00:23:48.194070 zmdc 1416 INF 'zmc -m 2' starting at 16/06/12 00:23:48, pid = 24031 zmdc.pl
2016-06-12 00:23:48.131810 zmdc 1416 INF 'zmc -m 2' exited normally zmdc.pl
2016-06-12 00:23:47.929909 zmc_m2 1780 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2016-06-12 00:23:47.922350 zmdc 1416 INF 'zmc -m 2' sending stop to pid 1780 at 16/06/12 00:23:47 zmdc.pl
2016-06-12 00:23:47.858580 zmdc 1416 WAR Can't find process with command of 'zma -m 2' zmdc.pl
2016-06-12 00:23:29.763490 zmc_m3 2656 INF Driveway: 2119000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-12 00:23:15.553268 zmc_m2 1780 INF Front_Door: 1413000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:22:23.168930 zmc_m3 2656 INF Driveway: 2118000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:21:35.547707 zmc_m2 1780 INF Front_Door: 1412000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:21:16.578111 zmc_m3 2656 INF Driveway: 2117000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:20:09.979563 zmc_m3 2656 INF Driveway: 2116000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-12 00:19:55.540864 zmc_m2 1780 INF Front_Door: 1411000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:19:03.388520 zmc_m3 2656 INF Driveway: 2115000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:18:15.546649 zmc_m2 1780 INF Front_Door: 1410000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:17:56.811575 zmc_m3 2656 INF Driveway: 2114000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-12 00:16:50.205330 zmc_m3 2656 INF Driveway: 2113000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:16:35.554544 zmc_m2 1780 INF Front_Door: 1409000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:15:43.611877 zmc_m3 2656 INF Driveway: 2112000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-12 00:14:55.546001 zmc_m2 1780 INF Front_Door: 1408000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:14:37.008622 zmc_m3 2656 INF Driveway: 2111000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:13:30.430878 zmc_m3 2656 INF Driveway: 2110000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:13:15.561079 zmc_m2 1780 INF Front_Door: 1407000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:12:23.801488 zmc_m3 2656 INF Driveway: 2109000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-12 00:11:35.544232 zmc_m2 1780 INF Front_Door: 1406000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:11:17.202700 zmc_m3 2656 INF Driveway: 2108000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:10:10.588304 zmc_m3 2656 INF Driveway: 2107000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-12 00:09:55.538452 zmc_m2 1780 INF Front_Door: 1405000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:09:04.008725 zmc_m3 2656 INF Driveway: 2106000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:08:15.549138 zmc_m2 1780 INF Front_Door: 1404000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:07:57.397044 zmc_m3 2656 INF Driveway: 2105000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:06:50.810548 zmc_m3 2656 INF Driveway: 2104000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-12 00:06:35.559618 zmc_m2 1780 INF Front_Door: 1403000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:05:44.193761 zmc_m3 2656 INF Driveway: 2103000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:04:55.530012 zmc_m2 1780 INF Front_Door: 1402000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:04:37.584354 zmc_m3 2656 INF Driveway: 2102000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:03:30.985883 zmc_m3 2656 INF Driveway: 2101000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-12 00:03:15.576922 zmc_m2 1780 INF Front_Door: 1401000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:02:24.390270 zmc_m3 2656 INF Driveway: 2100000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-12 00:01:35.578935 zmc_m2 1780 INF Front_Door: 1400000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-12 00:01:17.770191 zmc_m3 2656 INF Driveway: 2099000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-12 00:00:11.186964 zmc_m3 2656 INF Driveway: 2098000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:59:55.549431 zmc_m2 1780 INF Front_Door: 1399000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:59:04.586428 zmc_m3 2656 INF Driveway: 2097000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:58:15.568210 zmc_m2 1780 INF Front_Door: 1398000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:57:57.981895 zmc_m3 2656 INF Driveway: 2096000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:56:51.395670 zmc_m3 2656 INF Driveway: 2095000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:56:35.555639 zmc_m2 1780 INF Front_Door: 1397000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:55:44.801224 zmc_m3 2656 INF Driveway: 2094000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:54:55.547188 zmc_m2 1780 INF Front_Door: 1396000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:54:38.191954 zmc_m3 2656 INF Driveway: 2093000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:53:54.947645 web_php 1566 ERR socket_sendto( /var/run/zm/zms-244708s.sock ) failed: No such file or directory /usr/share/zoneminder/www/includes/functions.php 2371
2016-06-11 23:53:31.614833 zmc_m3 2656 INF Driveway: 2092000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:53:15.564831 zmc_m2 1780 INF Front_Door: 1395000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:52:25.012911 zmc_m3 2656 INF Driveway: 2091000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:51:35.552162 zmc_m2 1780 INF Front_Door: 1394000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:51:18.456837 zmc_m3 2656 INF Driveway: 2090000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:50:11.824579 zmc_m3 2656 INF Driveway: 2089000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:49:55.583334 zmc_m2 1780 INF Front_Door: 1393000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:49:05.233005 zmc_m3 2656 INF Driveway: 2088000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:48:15.580423 zmc_m2 1780 INF Front_Door: 1392000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:47:58.623302 zmc_m3 2656 INF Driveway: 2087000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:46:52.022188 zmc_m3 2656 INF Driveway: 2086000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:46:35.574682 zmc_m2 1780 INF Front_Door: 1391000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:45:45.450584 zmc_m3 2656 INF Driveway: 2085000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:44:55.580465 zmc_m2 1780 INF Front_Door: 1390000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:44:38.837293 zmc_m3 2656 INF Driveway: 2084000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:43:32.218393 zmc_m3 2656 INF Driveway: 2083000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:43:15.577426 zmc_m2 1780 INF Front_Door: 1389000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:42:25.609762 zmc_m3 2656 INF Driveway: 2082000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:41:35.576080 zmc_m2 1780 INF Front_Door: 1388000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:41:19.019101 zmc_m3 2656 INF Driveway: 2081000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:40:12.424151 zmc_m3 2656 INF Driveway: 2080000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:39:55.590961 zmc_m2 1780 INF Front_Door: 1387000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:39:05.841355 zmc_m3 2656 INF Driveway: 2079000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:38:15.572496 zmc_m2 1780 INF Front_Door: 1386000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:37:59.233283 zmc_m3 2656 INF Driveway: 2078000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:36:52.637909 zmc_m3 2656 INF Driveway: 2077000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:36:35.594248 zmc_m2 1780 INF Front_Door: 1385000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:35:46.057718 zmc_m3 2656 INF Driveway: 2076000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:34:55.599156 zmc_m2 1780 INF Front_Door: 1384000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:34:39.463265 zmc_m3 2656 INF Driveway: 2075000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:33:32.853059 zmc_m3 2656 INF Driveway: 2074000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:33:15.562069 zmc_m2 1780 INF Front_Door: 1383000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:32:26.263937 zmc_m3 2656 INF Driveway: 2073000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:31:35.582780 zmc_m2 1780 INF Front_Door: 1382000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:31:19.680983 zmc_m3 2656 INF Driveway: 2072000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:30:13.096841 zmc_m3 2656 INF Driveway: 2071000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:29:55.579616 zmc_m2 1780 INF Front_Door: 1381000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:29:06.490343 zmc_m3 2656 INF Driveway: 2070000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:28:15.615498 zmc_m2 1780 INF Front_Door: 1380000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:27:59.905321 zmc_m3 2656 INF Driveway: 2069000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:26:53.304153 zmc_m3 2656 INF Driveway: 2068000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:26:35.615839 zmc_m2 1780 INF Front_Door: 1379000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:25:46.721062 zmc_m3 2656 INF Driveway: 2067000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:24:55.598050 zmc_m2 1780 INF Front_Door: 1378000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:24:40.085749 zmc_m3 2656 INF Driveway: 2066000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:23:33.484802 zmc_m3 2656 INF Driveway: 2065000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:23:15.607108 zmc_m2 1780 INF Front_Door: 1377000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:22:26.895994 zmc_m3 2656 INF Driveway: 2064000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:21:35.610380 zmc_m2 1780 INF Front_Door: 1376000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:21:20.308427 zmc_m3 2656 INF Driveway: 2063000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:20:13.705556 zmc_m3 2656 INF Driveway: 2062000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:19:55.625081 zmc_m2 1780 INF Front_Door: 1375000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:19:07.101583 zmc_m3 2656 INF Driveway: 2061000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:18:15.596625 zmc_m2 1780 INF Front_Door: 1374000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:18:00.497545 zmc_m3 2656 INF Driveway: 2060000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:16:53.905438 zmc_m3 2656 INF Driveway: 2059000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:16:35.628185 zmc_m2 1780 INF Front_Door: 1373000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:15:47.298113 zmc_m3 2656 INF Driveway: 2058000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:14:55.631609 zmc_m2 1780 INF Front_Door: 1372000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:14:40.718328 zmc_m3 2656 INF Driveway: 2057000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:13:34.118422 zmc_m3 2656 INF Driveway: 2056000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:13:15.620032 zmc_m2 1780 INF Front_Door: 1371000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:12:27.537333 zmc_m3 2656 INF Driveway: 2055000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:11:35.619448 zmc_m2 1780 INF Front_Door: 1370000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:11:20.939902 zmc_m3 2656 INF Driveway: 2054000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:10:14.358634 zmc_m3 2656 INF Driveway: 2053000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:09:55.621930 zmc_m2 1780 INF Front_Door: 1369000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:09:07.756969 zmc_m3 2656 INF Driveway: 2052000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:08:15.617285 zmc_m2 1780 INF Front_Door: 1368000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:08:01.159089 zmc_m3 2656 INF Driveway: 2051000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:06:54.571758 zmc_m3 2656 INF Driveway: 2050000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:06:35.627538 zmc_m2 1780 INF Front_Door: 1367000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:05:47.991730 zmc_m3 2656 INF Driveway: 2049000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:04:55.594306 zmc_m2 1780 INF Front_Door: 1366000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:04:41.410550 zmc_m3 2656 INF Driveway: 2048000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:03:34.849843 zmc_m3 2656 INF Driveway: 2047000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:03:15.629927 zmc_m2 1780 INF Front_Door: 1365000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:02:28.235463 zmc_m3 2656 INF Driveway: 2046000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 23:01:35.637256 zmc_m2 1780 INF Front_Door: 1364000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 23:01:21.636676 zmc_m3 2656 INF Driveway: 2045000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 23:00:15.033729 zmc_m3 2656 INF Driveway: 2044000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 22:59:55.626312 zmc_m2 1780 INF Front_Door: 1363000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 22:59:08.446106 zmc_m3 2656 INF Driveway: 2043000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 22:58:15.621942 zmc_m2 1780 INF Front_Door: 1362000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 22:58:01.843591 zmc_m3 2656 INF Driveway: 2042000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 22:56:55.252144 zmc_m3 2656 INF Driveway: 2041000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 22:56:35.623232 zmc_m2 1780 INF Front_Door: 1361000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 22:55:48.668926 zmc_m3 2656 INF Driveway: 2040000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 22:54:55.633580 zmc_m2 1780 INF Front_Door: 1360000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 22:54:42.089322 zmc_m3 2656 INF Driveway: 2039000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 22:53:35.470863 zmc_m3 2656 INF Driveway: 2038000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 22:53:15.611628 zmc_m2 1780 INF Front_Door: 1359000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 22:52:28.883910 zmc_m3 2656 INF Driveway: 2037000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 22:51:35.644315 zmc_m2 1780 INF Front_Door: 1358000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 22:51:22.286620 zmc_m3 2656 INF Driveway: 2036000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 22:50:15.699938 zmc_m3 2656 INF Driveway: 2035000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 22:49:55.629935 zmc_m2 1780 INF Front_Door: 1357000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 22:49:09.104128 zmc_m3 2656 INF Driveway: 2034000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 22:48:15.632572 zmc_m2 1780 INF Front_Door: 1356000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 22:48:02.513063 zmc_m3 2656 INF Driveway: 2033000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 22:46:55.927182 zmc_m3 2656 INF Driveway: 2032000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 22:46:35.654186 zmc_m2 1780 INF Front_Door: 1355000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 22:45:49.360677 zmc_m3 2656 INF Driveway: 2031000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 22:44:55.638579 zmc_m2 1780 INF Front_Door: 1354000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 22:44:42.829426 zmc_m3 2656 INF Driveway: 2030000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 22:43:36.238446 zmc_m3 2656 INF Driveway: 2029000 - Capturing at 14.93 fps zm_monitor.cpp 3131
2016-06-11 22:43:15.658490 zmc_m2 1780 INF Front_Door: 1353000 - Capturing at 10.00 fps zm_monitor.cpp 3131
2016-06-11 22:42:29.673849 zmc_m3 2656 INF Driveway: 2028000 - Capturing at 15.15 fps zm_monitor.cpp 3131
2016-06-11 22:41:35.657955 zmc_m2 1780 INF Front_Door: 1352000 - Capturing at 10.00 fps zm_monitor.cpp 3131
