ZM 1.29 and BT878 - no display of camera
speedamaster
Post by speedamaster »
I installed ZM 1.29 on my Ubuntu 14.04.3 server.
Hardware is a BT878 video capturing card.
lspci
06:01.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
06:01.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Using xawtv, the video stream is perfectly shown.
xawtv /dev/video0
I did install cambozola.jar in /usr/share/zoneminder (and /usr/share/zoneminder/www), but all I get is:
ANY idea?
I used the following settings:
v4l
### v4l2 device info [/dev/video0] ###
general info
    VIDIOC_QUERYCAP
	driver                  : "bttv"
	card                    : "BT878 video (GrandTec Multi Cap"
	bus_info                : "PCI:0000:06:01.0"
	version                 : 3.13.11
	capabilities            : 0x85000015 [VIDEO_CAPTURE,VIDEO_OVERLAY,VBI_CAPTURE,READWRITE,STREAMING,(null)]
standards
    VIDIOC_ENUMSTD(0)
	index                   : 0
	id                      : 0xb000 [NTSC_M,NTSC_M_JP,?]
	frameperiod.numerator   : 1001
	frameperiod.denominator : 30000
	framelines              : 525
    VIDIOC_ENUMSTD(1)
	index                   : 1
	framelines              : 525
    VIDIOC_ENUMSTD(2)
	index                   : 2
	id                      : 0x2000 [NTSC_M_JP]
	framelines              : 525
    VIDIOC_ENUMSTD(3)
	index                   : 3
	framelines              : 525
    VIDIOC_ENUMSTD(4)
	index                   : 4
	id                      : 0xff [PAL_B,PAL_B1,PAL_G,PAL_H,PAL_I,PAL_D,PAL_D1,PAL_K]
	frameperiod.denominator : 25
	framelines              : 625
    VIDIOC_ENUMSTD(5)
	index                   : 5
	id                      : 0x7 [PAL_B,PAL_B1,PAL_G]
	framelines              : 625
    VIDIOC_ENUMSTD(6)
	index                   : 6
	framelines              : 625
    VIDIOC_ENUMSTD(7)
	index                   : 7
	framelines              : 625
    VIDIOC_ENUMSTD(8)
	index                   : 8
	id                      : 0xe0 [PAL_D,PAL_D1,PAL_K]
	framelines              : 625
    VIDIOC_ENUMSTD(9)
	index                   : 9
	framelines              : 525
    VIDIOC_ENUMSTD(10)
	index                   : 10
	framelines              : 625
    VIDIOC_ENUMSTD(11)
	index                   : 11
	framelines              : 625
    VIDIOC_ENUMSTD(12)
	index                   : 12
	framelines              : 525
    VIDIOC_ENUMSTD(13)
	index                   : 13
	id                      : 0xff0000 [SECAM_B,SECAM_D,SECAM_G,SECAM_H,SECAM_K,SECAM_K1,SECAM_L,?ATSC_8_VSB]
	framelines              : 625
    VIDIOC_ENUMSTD(14)
	index                   : 14
	id                      : 0x10000 [SECAM_B]
	framelines              : 625
    VIDIOC_ENUMSTD(15)
	index                   : 15
	id                      : 0x40000 [SECAM_G]
	framelines              : 625
    VIDIOC_ENUMSTD(16)
	index                   : 16
	id                      : 0x80000 [SECAM_H]
	framelines              : 625
    VIDIOC_ENUMSTD(17)
	index                   : 17
	id                      : 0x320000 [SECAM_D,SECAM_K,SECAM_K1]
	framelines              : 625
    VIDIOC_ENUMSTD(18)
	index                   : 18
	id                      : 0x400000 [SECAM_L]
	framelines              : 625
    VIDIOC_ENUMSTD(19)
	index                   : 19
	id                      : 0x800000 [?ATSC_8_VSB]
	framelines              : 625
inputs
    VIDIOC_ENUMINPUT(0)
	index                   : 0
	type                    : CAMERA
	audioset                : 0
	tuner                   : 0
	std                     : 0xffbfff [PAL_B,PAL_B1,PAL_G,PAL_H,PAL_I,PAL_D,PAL_D1,PAL_K,PAL_M,PAL_N,PAL_Nc,PAL_60,NTSC_M,NTSC_M_JP,?,SECAM_B,SECAM_D,SECAM_G,SECAM_H,SECAM_K,SECAM_K1,SECAM_L,?ATSC_8_VSB]
	status                  : 0x0 []
    VIDIOC_ENUMINPUT(1)
	index                   : 1
	type                    : CAMERA
	audioset                : 0
	tuner                   : 0
	status                  : 0x0 []
    VIDIOC_ENUMINPUT(2)
	index                   : 2
	type                    : CAMERA
	audioset                : 0
	tuner                   : 0
	status                  : 0x0 []
    VIDIOC_ENUMINPUT(3)
	index                   : 3
	type                    : CAMERA
	audioset                : 0
	tuner                   : 0
	status                  : 0x0 []
video capture
    VIDIOC_ENUM_FMT(0,VIDEO_CAPTURE)
	index                   : 0
	type                    : VIDEO_CAPTURE
	flags                   : 0
	description             : "8 bpp, gray"
	pixelformat             : 0x59455247 [GREY]
    VIDIOC_ENUM_FMT(1,VIDEO_CAPTURE)
	index                   : 1
	flags                   : 0
	description             : "8 bpp, dithered color"
	pixelformat             : 0x34324948 [HI24]
    VIDIOC_ENUM_FMT(2,VIDEO_CAPTURE)
	index                   : 2
	flags                   : 0
	description             : "15 bpp RGB, le"
	pixelformat             : 0x4f424752 [RGBO]
    VIDIOC_ENUM_FMT(3,VIDEO_CAPTURE)
	index                   : 3
	flags                   : 0
	description             : "15 bpp RGB, be"
	pixelformat             : 0x51424752 [RGBQ]
    VIDIOC_ENUM_FMT(4,VIDEO_CAPTURE)
	index                   : 4
	flags                   : 0
	description             : "16 bpp RGB, le"
	pixelformat             : 0x50424752 [RGBP]
    VIDIOC_ENUM_FMT(5,VIDEO_CAPTURE)
	index                   : 5
	flags                   : 0
	description             : "16 bpp RGB, be"
	pixelformat             : 0x52424752 [RGBR]
    VIDIOC_ENUM_FMT(6,VIDEO_CAPTURE)
	index                   : 6
	flags                   : 0
	description             : "24 bpp RGB, le"
	pixelformat             : 0x33524742 [BGR3]
    VIDIOC_ENUM_FMT(7,VIDEO_CAPTURE)
	index                   : 7
	flags                   : 0
	description             : "32 bpp RGB, le"
	pixelformat             : 0x34524742 [BGR4]
    VIDIOC_ENUM_FMT(8,VIDEO_CAPTURE)
	index                   : 8
	flags                   : 0
	description             : "32 bpp RGB, be"
	pixelformat             : 0x34424752 [RGB4]
    VIDIOC_ENUM_FMT(9,VIDEO_CAPTURE)
	index                   : 9
	flags                   : 0
	description             : "4:2:2, packed, YUYV"
	pixelformat             : 0x56595559 [YUYV]
    VIDIOC_ENUM_FMT(10,VIDEO_CAPTURE)
	index                   : 10
	flags                   : 0
	description             : "4:2:2, packed, UYVY"
	pixelformat             : 0x59565955 [UYVY]
    VIDIOC_ENUM_FMT(11,VIDEO_CAPTURE)
	index                   : 11
	flags                   : 0
	description             : "4:2:2, planar, Y-Cb-Cr"
	pixelformat             : 0x50323234 [422P]
    VIDIOC_ENUM_FMT(12,VIDEO_CAPTURE)
	index                   : 12
	flags                   : 0
	description             : "4:2:0, planar, Y-Cb-Cr"
	pixelformat             : 0x32315559 [YU12]
    VIDIOC_ENUM_FMT(13,VIDEO_CAPTURE)
	index                   : 13
	flags                   : 0
	description             : "4:2:0, planar, Y-Cr-Cb"
	pixelformat             : 0x32315659 [YV12]
    VIDIOC_ENUM_FMT(14,VIDEO_CAPTURE)
	index                   : 14
	flags                   : 0
	description             : "4:1:1, planar, Y-Cb-Cr"
	pixelformat             : 0x50313134 [411P]
    VIDIOC_ENUM_FMT(15,VIDEO_CAPTURE)
	index                   : 15
	flags                   : 0
	description             : "4:1:0, planar, Y-Cb-Cr"
	pixelformat             : 0x39565559 [YUV9]
    VIDIOC_ENUM_FMT(16,VIDEO_CAPTURE)
	index                   : 16
	flags                   : 0
	description             : "4:1:0, planar, Y-Cr-Cb"
	pixelformat             : 0x39555659 [YVU9]
    VIDIOC_G_FMT(VIDEO_CAPTURE)
	fmt.pix.width           : 384
	fmt.pix.height          : 288
	fmt.pix.pixelformat     : 0x34524742 [BGR4]
	fmt.pix.field           : INTERLACED
	fmt.pix.bytesperline    : 1536
	fmt.pix.sizeimage       : 442368
	fmt.pix.colorspace      : SMPTE170M
	fmt.pix.priv            : 0
video overlay
    VIDIOC_ENUM_FMT(0,VIDEO_OVERLAY)
	index                   : 0
	type                    : VIDEO_OVERLAY
	flags                   : 0
    VIDIOC_ENUM_FMT(1,VIDEO_OVERLAY)
	index                   : 1
	flags                   : 0
    VIDIOC_ENUM_FMT(2,VIDEO_OVERLAY)
	index                   : 2
	flags                   : 0
    VIDIOC_ENUM_FMT(3,VIDEO_OVERLAY)
	index                   : 3
	flags                   : 0
    VIDIOC_ENUM_FMT(4,VIDEO_OVERLAY)
	index                   : 4
	flags                   : 0
    VIDIOC_ENUM_FMT(5,VIDEO_OVERLAY)
	index                   : 5
	flags                   : 0
    VIDIOC_ENUM_FMT(6,VIDEO_OVERLAY)
	index                   : 6
	flags                   : 0
    VIDIOC_ENUM_FMT(7,VIDEO_OVERLAY)
	index                   : 7
	flags                   : 0
    VIDIOC_ENUM_FMT(8,VIDEO_OVERLAY)
	index                   : 8
	flags                   : 0
    VIDIOC_ENUM_FMT(9,VIDEO_OVERLAY)
	index                   : 9
	flags                   : 0
    VIDIOC_ENUM_FMT(10,VIDEO_OVERLAY)
	index                   : 10
	flags                   : 0
    VIDIOC_G_FMT(VIDEO_OVERLAY)
	fmt.win.w.left          : 0
	fmt.win.w.top           : 0
	fmt.win.w.width         : 320
	fmt.win.w.height        : 240
	fmt.win.field           : INTERLACED
	fmt.win.chromakey       : 0
	fmt.win.clips           : (nil)
	fmt.win.clipcount       : 0
	fmt.win.bitmap          : (nil)
    VIDIOC_G_FBUF
	capability              : 0x4 [LIST_CLIPPING]
	flags                   : 0x1 [PRIMARY]
	base                    : (nil)
	fmt.width               : 1680
	fmt.height              : 1050
	fmt.pixelformat         : 0x34524742 [BGR4]
	fmt.field               : ANY
	fmt.bytesperline        : 6720
	fmt.sizeimage           : 0
	fmt.colorspace          : unknown
	fmt.priv                : 0
vbi capture
controls
    VIDIOC_QUERYCTRL(BASE+0)
	type                    : INTEGER
	minimum                 : 0
	maximum                 : 65280
	step                    : 256
	default_value           : 32768
	flags                   : 32
    VIDIOC_QUERYCTRL(BASE+1)
	type                    : INTEGER
	minimum                 : 0
	maximum                 : 65408
	step                    : 128
	default_value           : 27648
	flags                   : 32
    VIDIOC_QUERYCTRL(BASE+2)
	type                    : INTEGER
	minimum                 : 0
	maximum                 : 65408
	step                    : 128
	flags                   : 32
    VIDIOC_QUERYCTRL(BASE+3)
	type                    : INTEGER
	minimum                 : 0
	maximum                 : 65280
	step                    : 256
	flags                   : 32
    VIDIOC_QUERYCTRL(BASE+9)
	type                    : BOOLEAN
	minimum                 : 0
	maximum                 : 1
	step                    : 1
	default_value           : 0
	flags                   : 0
    VIDIOC_QUERYCTRL(BASE+29)
	type                    : BOOLEAN
	minimum                 : 0
	maximum                 : 1
	step                    : 1
	default_value           : 0
	flags                   : 0
    VIDIOC_QUERYCTRL(BASE+30)
	type                    : BOOLEAN
	minimum                 : 0
	maximum                 : 1
	step                    : 1
	default_value           : 0
	flags                   : 0
    VIDIOC_QUERYCTRL(PRIVATE_BASE+0)
	type                    : BOOLEAN
	minimum                 : 0
	maximum                 : 1
	step                    : 1
	default_value           : 0
	flags                   : 0
    VIDIOC_QUERYCTRL(PRIVATE_BASE+1)
	type                    : BOOLEAN
	minimum                 : 0
	maximum                 : 1
	step                    : 1
	default_value           : 1
	flags                   : 0
    VIDIOC_QUERYCTRL(PRIVATE_BASE+2)
	type                    : BOOLEAN
	name                    : "Luma Decimation Filter"
	minimum                 : 0
	maximum                 : 1
	step                    : 1
	default_value           : 0
	flags                   : 0
    VIDIOC_QUERYCTRL(PRIVATE_BASE+3)
	type                    : BOOLEAN
	minimum                 : 0
	maximum                 : 1
	step                    : 1
	default_value           : 1
	flags                   : 0
    VIDIOC_QUERYCTRL(PRIVATE_BASE+4)
	type                    : BOOLEAN
	minimum                 : 0
	maximum                 : 1
	step                    : 1
	default_value           : 0
	flags                   : 0
    VIDIOC_QUERYCTRL(PRIVATE_BASE+5)
	type                    : INTEGER
	minimum                 : 0
	maximum                 : 255
	step                    : 1
	default_value           : 127
	flags                   : 0
    VIDIOC_QUERYCTRL(PRIVATE_BASE+6)
	type                    : INTEGER
	minimum                 : 0
	maximum                 : 255
	step                    : 1
	default_value           : 207
	flags                   : 0
    VIDIOC_QUERYCTRL(PRIVATE_BASE+7)
	type                    : INTEGER
	minimum                 : 0
	maximum                 : 100
	step                    : 1
	default_value           : 50
	flags                   : 0
    VIDIOC_QUERYCTRL(PRIVATE_BASE+8)
	type                    : BOOLEAN
	name                    : "Full Luma Range"
	minimum                 : 0
	maximum                 : 1
	step                    : 1
	default_value           : 0
	flags                   : 0
    VIDIOC_QUERYCTRL(PRIVATE_BASE+9)
	type                    : INTEGER
	minimum                 : 0
	maximum                 : 3
	step                    : 1
	default_value           : 0
	flags                   : 0
zmu
Video Device: /dev/video0
General Capabilities
  Driver: bttv
  Card: BT878 video (GrandTec Multi Cap
  Bus: PCI:0000:06:01.0
  Version: 3.13.11
  Type: 0x85000015
    Supports video capture (X)
    Does not support video output
    Supports frame buffer overlay
    Supports VBI capture
    Does not support VBI output
    Does not have tuner
    Does not have radio
    Supports read/write i/o (X)
    Does not support async i/o
    Supports streaming i/o (X)
    Standards:
      NTSC
      NTSC-M
      NTSC-M-JP
      NTSC-M-KR
      PAL
      PAL-BG
      PAL-H
      PAL-I
      PAL-DK
      PAL-M
      PAL-N
      PAL-Nc
      PAL-60
      SECAM
      SECAM-B
      SECAM-G
      SECAM-H
      SECAM-DK
      SECAM-L
      SECAM-Lc
  Formats:
    8 bpp, gray (GREY)
    8 bpp, dithered color (HI24)
    15 bpp RGB, le (RGBO)
    15 bpp RGB, be (RGBQ)
    16 bpp RGB, le (RGBP)
    16 bpp RGB, be (RGBR)
    24 bpp RGB, le (BGR3)
    32 bpp RGB, le (BGR4)
    32 bpp RGB, be (RGB4)
    4:2:2, packed, YUYV (YUYV)
    4:2:2, packed, UYVY (UYVY)
    4:2:2, planar, Y-Cb-Cr (422P)
    4:2:0, planar, Y-Cb-Cr (YU12)
    4:2:0, planar, Y-Cr-Cb (YV12)
    4:1:1, planar, Y-Cb-Cr (411P)
    4:1:0, planar, Y-Cb-Cr (YUV9)
    4:1:0, planar, Y-Cr-Cb (YVU9)
Crop Capabilities
  Bounds: 1063 x 608
  Default: 924 x 576
  Current: 924 x 576
Inputs: 4
  Input 0
    Type: Camera
    Audioset: 00000000
    Standards: 0xffbfff
    Power on  (X)
    Signal detected  (X)
    Colour Signal detected
    Horizontal Lock detected
  Input 1
    Type: Camera
    Audioset: 00000000
    Standards: 0xffbfff
    Power on  (X)
    Signal detected  (X)
  Input 2
    Type: Camera
    Audioset: 00000000
    Standards: 0xffbfff
    Power on  (X)
    Signal detected  (X)
  Input 3
    Type: Camera
    Audioset: 00000000
    Standards: 0xffbfff
    Power on  (X)
    Signal detected  (X)
speedamaster
Re: ZM 1.29 and BT878 - no display of camera
caus might be in java/cambozola/.... settings.....
You likely forgot the last step in the install or upgrade procedure!
hayate
Post by hayate »
look your logs in zoneminder top right of the interface look if there some socket errors..
speedamaster
@bbunge what is the last step in installation/ upograde procedure?
@hayate log is empty - maybe I have to increase the log level - will try
