Page 1 of 5
Ubuntu 16.04 Release with Zoneminder 1.29.0
Posted: Thu Apr 21, 2016 1:50 pm
by bbunge
I have verified the "Easy" Zoneminder 1.29.0 install procedure on the released Ubuntu 16.04 LTS!
Please be aware that you will have to make some configuration changes to Apache and MySQL. These steps are included in the procedure.
I have completed and tested the procedure to upgrade MySQL 5.7 to Mariadb 10. The cleanest way to do this is before installing Zoneminder but there is a procedure to upgrade to Mariadb with Zoneminder (or other databases) installed.
As with all my procedures I try to do them so a Linux novice can get Zoneminder running easily. But you have to follow all of the steps!
Bill
Re: Ubuntu 16.04 Release with Zoneminder 1.29.0
Posted: Thu Apr 21, 2016 2:33 pm
by asker
Bill, did you face any issues with MySQL 5.7? Why did you choose to move to Mariadb?
Posted: Thu Apr 21, 2016 3:26 pm
by bbunge
asker wrote:Bill, did you face any issues with MySQL 5.7? Why did you choose to move to Mariadb?
I did have issues with MySQL 5.7 which were overcome by adding sql_mode = NO_ENGINE_SUBSTITUTION to my.cnf. Otherwise MySQL 5.7 works OK.
I chose to include the option to use Mariadb because I could and it provides another option. Centos 7 uses Mariadb. I feel it runs smoother than MySQL.
As of this I recommend switching to Mariadb before installing Zoneminder (new install) as the Zoneminder database will not be copied to the new directory. I will work out procedures to upgrade a running ZM system with Mariadb but it may take me time. There are other important things like a long bike ride before it rains this afternoon!
Stay tuned
Oh Mariadb upgrade procedures have been tested:
https://wiki.zoneminder.com/Ubuntu_Serv ... erver_10.0.
Posted: Fri Apr 22, 2016 11:27 pm
by hondaman
I just want to thank you bbunge for writing that. I followed it yesterday to get zm installed. I'm glad I found it, I was trying to use some of the older guides and was getting tripped up by some differences.
Posted: Fri Apr 22, 2016 11:42 pm
by bbunge
hondaman wrote:I just want to thank you bbunge for writing that. I followed it yesterday to get zm installed. I'm glad I found it, I was trying to use some of the older guides and was getting tripped up by some differences.
Glad it worked for you!
bb
Posted: Fri Apr 22, 2016 11:49 pm
by hondaman
bbunge wrote:hondaman wrote:I just want to thank you bbunge for writing that. I followed it yesterday to get zm installed. I'm glad I found it, I was trying to use some of the older guides and was getting tripped up by some differences.
bb
There was one small error. And in full disclosure I didn't follow your advice about " I recommend you move the config file and replace the default my.cnf symbolic link. ", I simply edited my.cnf in place, as it was installed by Ubuntu.
In this portion of the guide:
Underneath [mysql] add the following
[mysql] didn't exit, so I had to add it after I loooked around the internet to make sure that was the correct thing to do.
Posted: Sun Apr 24, 2016 1:58 am
by bbunge
Actually, what you think is an error isn't. It is just another way of skinning the cat.
If you follow the symbolic links, two of them in the default LAMP install, you get back to /etc/mysql/mysql.cnf which is a pretty basic config file that relies on the MySQL 5.7 default settings. That, in a nutshell, is why I recommend replacing the first /etc/mysql/my.cnf symbolic link with a real configuration file. If you run Zoneminder long enough with lots of events, you will have to tune the MySQL, or Mariadb, settings.
bb
Posted: Mon Apr 25, 2016 1:25 am
by borism
Hi
Ubuntu 16.04 MySql Server 5.7.11-0ubuntu6 PHP7.0
The (sql_mode = NO_ENGINE_SUBSTITUTION) does not work - ERROR!!!!
root@orion-15:~# mysql -uroot -p < /usr/share/zoneminder/db/zm_create.sql
mysql: [ERROR] unknown variable 'sql_mode=NO_ENGINE_SUBSTITUTION'
my.cnf (link - /etc/mysql/mysql.conf.d/mysqld.cnf)
/etc/mysql/my.cnf 808/3241 24%
# The MySQL database server configuration file.
[mysqld_safe]
socket = /var/run/mysqld/mysqld.sock
nice = 0
[mysqld]
# * Basic Settings
user = mysql
pid-file = /var/run/mysqld/mysqld.pid
port = 3306
basedir = /usr
datadir = /var/lib/mysql
tmpdir = /tmp
lc-messages-dir = /usr/share/mysql
skip-external-locking
# Instead of skip-networking the default is now to listen only on
# localhost which is more compatible and is not less secure.
bind-address = 127.0.0.1
# * Fine Tuning
key_buffer_size = 16M
max_allowed_packet = 16M
thread_stack = 192K
thread_cache_size = 8
# This replaces the startup script and checks MyISAM tables if needed
# the first time they are touched
myisam-recover-options = BACKUP
#max_connections = 100
#table_cache = 64
#thread_concurrency = 10
# * Query Cache Configuration
query_cache_limit = 1M
query_cache_size = 16M
# * Logging and Replication
# Both location gets rotated by the cronjob.
# Be aware that this log type is a performance killer.
# As of 5.1 you can enable the log at runtime!
#general_log_file = /var/log/mysql/mysql.log
#general_log = 1
# Error log - should be very few entries.
log_error = /var/log/mysql/error.log
# Here you can see queries with especially long duration
#log_slow_queries = /var/log/mysql/mysql-slow.log
#long_query_time = 2
#log-queries-not-using-indexes
# The following can be used as easy to replay backup logs or for replication.
# note: if you are setting up a replication slave, see README.Debian about
# other settings you may need to change.
#server-id = 1
#log_bin = /var/log/mysql/mysql-bin.log
expire_logs_days = 10
max_binlog_size = 100M
#binlog_do_db = include_database_name
#binlog_ignore_db = include_database_name
# * InnoDB
# InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
# Read the manual for more InnoDB related options. There are many!
# * Security Features
# Read the manual, too, if you want chroot!
# chroot = /var/lib/mysql/
# For generating SSL certificates I recommend the OpenSSL GUI "tinyca".
# ssl-ca=/etc/mysql/cacert.pem
# ssl-cert=/etc/mysql/server-cert.pem
# ssl-key=/etc/mysql/server-key.pem
# dop my minimum mem
skip-name-resolve
skip-federated
# dop kodirovka
skip-character-set-client-handshake
character-set-server = utf8
collation-server = utf8_unicode_ci
[mysql]
what should I do
Posted: Mon Apr 25, 2016 2:45 am
by hondaman
My /etc/mysql/my.cnf looks like this in its entirety
http://pastebin.com/KWhpqwgx
I manually added these two lines:
[mysqld]
borism wrote:Hi
[mysqld_safe]
nice = 0
[mysqld]
# * Basic Settings
user = mysql
port = 3306
basedir = /usr
tmpdir = /tmp
# * Fine Tuning
thread_stack = 192K
#table_cache = 64
#general_log = 1
#server-id = 1
# * InnoDB
skip-name-resolve
skip-federated
# dop kodirovka
[mysql]
what should I do
Posted: Mon Apr 25, 2016 2:51 am
by bbunge
When all else fails, read and follow the instructions!
Posted: Mon Apr 25, 2016 3:02 am
by hondaman
I just took a closer look at the instructions you wrote (that I skipped), and I did in fact just now find an error.
cp /etc/mysql/mysql.conf.d/mysqld.cnf /etc/mysql/my.cnf
That isn't a valid path. It should read:
cp /etc/mysql/conf.d/mysql.cnf /etc/mysql/my.cnf
bbunge wrote:When all else fails, read and follow the instructions!
Posted: Mon Apr 25, 2016 4:37 am
by SteveGilvarry
Interesting /etc/mysql/mysql.conf.d/mysqld.cnf is correct on my Mysql in 16.04. I believe the prefix was added to allow mariadb and mysql configuration to be kept separate. My /etc/mysql/conf.d/mysql.cnf is essentially empty.
Posted: Mon Apr 25, 2016 4:54 am
by hondaman
Oh gosh. I'm probably 0-2 now and should probably quit trying to break stuff that aint broke.
Posted: Mon Apr 25, 2016 1:06 pm
by bbunge
hondaman wrote:Oh gosh. I'm probably 0-2 now and should probably quit trying to break stuff that aint broke.
That's OK. As I'm a hunt and peck typer I do make mistakes so it is good for someone to double check me! Spell check does not do well with code entries.
Posted: Mon Apr 25, 2016 1:23 pm
by philip_d
Hi, Everyone,
Is there anybody that can help me regarding 1.29 version.Below is the error when I connect on the browser. I changed already the timezone but still the same.I'm using Unbuntu LTS16.04 Server
ZoneMinder is not installed properly: php's date.timezone is not set to a valid timezone
