Ubuntu 16.04 Release with Zoneminder 1.29.0
Re: Ubuntu 16.04 Release with Zoneminder 1.29.0
Post by bbunge » Sat Apr 30, 2016 11:12 pm
iconnor wrote:You havn't set the timezone is the right php.ini file. Normally the one you need to edit is /etc/php/apache2/php.ini
For Ubuntu 16.04 it is: nano /etc/php/7.0/apache2/php.ini
With that said it may be different if you have done an upgrade. However, I have not successfully upgraded a running ZM Ubuntu install to 16.04 since the official release. Am having issues with MySQL going from 5.5 (14.04) or 5.6 (15.10) to 5.7 (16.04). Will get it to work in time...
Sigge
Post by Sigge » Mon May 02, 2016 8:23 am
Hi and thanks for the instructions.
I ran in to a lot of trubble from anouther service blocking the install of mysql. Solved that but I am now unable to start apache2.
Anyone knows what the problem is? PHP not properly installed?
Log:
apache2.service - LSB: Apache2 web server
Loaded: loaded (/etc/init.d/apache2; bad; vendor preset: enabled)
Drop-In: /lib/systemd/system/apache2.service.d
└─apache2-systemd.conf
Active: failed (Result: exit-code) since lun 2016-05-02 09:57:47 CEST; 6min ago
Docs: man:systemd-sysv-generator(8)
Process: 1225 ExecStart=/etc/init.d/apache2 start (code=exited, status=1/FAILURE)
mag 02 09:57:47 BERTILIT apache2[1225]: * The apache2 configtest failed.
mag 02 09:57:47 BERTILIT apache2[1225]: Output of config test was:
mag 02 09:57:47 BERTILIT apache2[1225]: AH00526: Syntax error on line 11 of /etc/apache2/conf-enabled/zoneminder.conf:
mag 02 09:57:47 BERTILIT apache2[1225]: Invalid command 'php_flag', perhaps misspelled or defined by a module not included in the server configuration
mag 02 09:57:47 BERTILIT apache2[1225]: Action 'configtest' failed.
mag 02 09:57:47 BERTILIT apache2[1225]: The Apache error log may have more information.
mag 02 09:57:47 BERTILIT systemd[1]: apache2.service: Control process exited, code=exited status=1
mag 02 09:57:47 BERTILIT systemd[1]: Failed to start LSB: Apache2 web server.
mag 02 09:57:47 BERTILIT systemd[1]: apache2.service: Unit entered failed state.
mag 02 09:57:47 BERTILIT systemd[1]: apache2.service: Failed with result 'exit-code'.
Thanks!
SteveGilvarry
Post by SteveGilvarry » Mon May 02, 2016 9:19 am
sudo apt-get install libapache2-mod-php
Production Zoneminder 1.35.x
More Dev VM's than I care to count.
Sigge
Post by Sigge » Mon May 02, 2016 11:49 am
Thanks but it did not work:
libapache2-mod-php is already the newest version (1:7.0+35ubuntu6).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
MJN
Post by MJN » Mon May 02, 2016 12:31 pm
You might need to enable it:
sudo a2enmod php
(Might need to check the 'php' descriptor - I'm not at my machine right now to check the exact name)
SteveGilvarry
Post by SteveGilvarry » Mon May 02, 2016 12:32 pm
Is it enabled? That error is saying it doesn't understand php_flag, which is a perfectly legitimate command in zoneminder.conf if php module is loaded.
apachectl -M should see php7_module in the list.
SteveGilvarry
Post by SteveGilvarry » Mon May 02, 2016 12:55 pm
Once you get it working, i.e. you know php is loaded and working, then delete this line
php_flag register_globals off
from zoneminder.conf. It is deprecated in PHP 5.4, that is register_globals is always off.
Post by bbunge » Mon May 02, 2016 1:13 pm
I've just gotten an upgrade from Ubuntu 14.04 - ZM 1.29.0 to 16.04 - 1.29.0 to work. Folks, it was not pretty! I need to do it again to document the steps. I, too, had a problem with the php_flag... which I'll tell you how to fix when I get it written up.
bb
Sigge
Post by Sigge » Mon May 02, 2016 2:08 pm
Commenting it away makes the apache2 server start.
But localhost/zm is blank.
I created a /var/www/html/info.php conaining:
<?php
phpinfo();
and that is blanc as well.
I think there is some problem with PHP?
Thanks,
Post by bbunge » Mon May 02, 2016 2:17 pm
Sigge wrote:Commenting it away makes the apache2 server start.
<?php
phpinfo();
Thanks,
Did you try to do an upgrade? If so you will have issues which I am working on.
If you did a fresh install of Ubuntu 16.04 these instructions work: https://wiki.zoneminder.com/Ubuntu_Serv ... e_easy_way
SteveGilvarry
Post by SteveGilvarry » Mon May 02, 2016 2:26 pm
You literally did the last thing I suggested, I did say once you get it working then you can comment it out.
apachectl -M and check if any php entries listed.
Sigge
Post by Sigge » Mon May 02, 2016 2:32 pm
@SteveGilvary: I did all but apachectl -M did not work with apache down.
Now:
apachectl -M
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
Loaded Modules:
core_module (static)
so_module (static)
watchdog_module (static)
http_module (static)
log_config_module (static)
logio_module (static)
version_module (static)
unixd_module (static)
access_compat_module (shared)
alias_module (shared)
auth_basic_module (shared)
authn_core_module (shared)
authn_file_module (shared)
authz_core_module (shared)
authz_host_module (shared)
authz_user_module (shared)
autoindex_module (shared)
cgid_module (shared)
deflate_module (shared)
dir_module (shared)
env_module (shared)
filter_module (shared)
mime_module (shared)
mpm_event_module (shared)
negotiation_module (shared)
rewrite_module (shared)
setenvif_module (shared)
status_module (shared)
No php?
MJN
Post by MJN » Mon May 02, 2016 2:43 pm
Did you enable it?
Post by bbunge » Mon May 02, 2016 3:06 pm
Upgrade procedure for Ubuntu 14.04 - ZM 1.29.0 to Ubuntu 16.04 - ZM 1.29.0 is ready. See:
https://wiki.zoneminder.com/Common_Issu ... untu_16.04
Post by bbunge » Mon May 02, 2016 3:11 pm
If your Apache2 is having problems starting in Ubuntu 16.04 with a php_flag error, check that all the required PHP programs are installed:
apt-get install php php-gd libapache2-mod-php php7.0-mysql
You will also need to set your timezone in /etc/php/7.0/apache2/php.ini
Users browsing this forum: No registered users and 0 guests
