Page 1 of 1
Socket error - failed: No such file or directory
Posted: Sun Apr 03, 2016 7:57 am
by FvdLaar
Hallo forum members,
My new Zoneminder 1.29 on Ubuntu 14.04 is working except for viewing streams (watching a monitor or replay events). I can watch individual frames and alarm detection is working fine.
After installing 1.29 from ppa::iconnor having the socket error: [socket_sendto( /var/run/zm/zms-841293s.sock ) failed: No such file or directory], referer: https:/ /www.example.com/zm/index.php?view=watch&mid=1
Can't figure out why socket is not being made!
For clean installation I followed : http://zoneminder.readthedocs.org/en/la ... buntu-14-x
Tried without success: https://bugs.launchpad.net/ubuntu/+sour ... ug/1159361 step #8
Regards,
Frank
Re: Socket error - failed: No such file or directory
Posted: Sun Apr 03, 2016 12:44 pm
by bbunge
Another set of instructions:
You may need to
chmod 740 /etc/zm/zm.conf
Create a new user
adduser www-data video
Socket sento errors can be caused by several things. Restarting ZM while watching stream or montage, watching stream or montage from the same login name. Neither are really setup problems but do fill up the log with lots of red.
Posted: Sun Apr 03, 2016 4:13 pm
by FvdLaar
Followed https://wiki.zoneminder.com/Ubuntu_Serv ... e_easy_way at an earlier try. Didn't work for me.
Followed your suggestion to check and change permission and ownership of /etc/zm/zm.conf, but didn't help either.
I also believe it isn't a setup of config issue within the Zoneminder 1.29 parameters, but .... it used to work with Zoneminder 1.28 which I completely removed.
A solution could be starting again with Zoneminder 1.28, make it work and try to upgrade to 1.29
But I'am wondering what the difference is between 1.28 and 1.29 that might be the cause of the socket failure.
Note: I don't see any socket file being made accept for :
webmanager@localhost:~$ ls /var/run/zm -al
total 4
drwxr-xr-x  2 www-data www-data  80 apr  3 18:02 .
drwxr-xr-x 25 root     root     880 apr  3 17:56 ..
srwxr-xr-x  1 www-data www-data   0 apr  3 18:02 zmdc.sock
-rw-r--r--  1 www-data www-data   5 apr  3 18:02 zm.pid
Posted: Sun Apr 03, 2016 4:58 pm
by bbunge
Maybe you should start with a fresh Ubuntu install? I just ran the Ubuntu 14.04 with ZM 1.29.0 yesterday and had no issues.
As I said, it may not be ZM that is causing the socket sendto "errors" Could be your browser...
Posted: Sun Apr 03, 2016 6:11 pm
by FvdLaar
The zoneminder web page is trying to open http:/ /localhost/zm/cgi-bin/nph-zms?mode=jpeg&scale=100&maxfps=5&buffer=1000&monitor=1&auth=.......
Copy-pasting this to my browser gives following: The requested URL /zm/cgi-bin/nph-zms was not found on this server.
Hence, cgi-bin seems to be the problem. I'll check apache and site config again:
/etc/zm/zm.conf
# Path to ZoneMinder web files
ZM_PATH_WEB=/usr/share/zoneminder/www
# Path to ZoneMinder cgi files
ZM_PATH_CGI=/usr/lib/zoneminder/cgi-bin
Where is nph-cgi and what permissions and ownership does it have?
webmanager@localhost:~$ ls /usr/lib/zoneminder/cgi-bin -al
total 1460
drwxr-xr-x 2 root root    4096 apr  2 17:05 .
drwxr-xr-x 3 root root    4096 apr  2 17:05 ..
lrwxrwxrwx 1 root root       3 feb  4 18:43 nph-zms -> zms
-rwxr-xr-x 1 root root 1485336 feb  4 18:43 zms
Zoneminder options, path settings:
PATH_ZMS     Web path to zms streaming server (?)                                     /zm/cgi-bin/nph-zms
PATH_SOCKS   Path to the various Unix domain socket files that ZoneMinder uses (?)    /var/run/zm
SOLVED - Re: Socket error - failed: No such file or directory
Posted: Fri Apr 15, 2016 8:16 pm
by FvdLaar
After long investigation I found out it's a webserver config mistake!
I can't and I shouldn't combine an active zoneminder.conf while having a virtual host running in which its site configuration includes "Alias /zm /usr/share/zoneminder/www"!
That messes up the objective of ScriptAlias in the zoneminder.conf
Apache2 on Ubuntu 14.04 or later:
- disable all sites (list of sites by executing command line: "sudo ls /etc/apache2/sites-enabled -al")
- enable zoneminder.conf
- restart of reload Apache
Gives a list of site config files like follow example:
default-000.conf
sudo a2dissite default-000
Repeat for all of my sites.
sudo a2enconf zoneminder
To enable zoneminder.conf
sudo service apache2 reload
To start webserver with new config.
Worked for me as long as I followed the regular installation instructions!
Even provides the solution for a similar problem when trying a clean install of Zoneminder on Docker on top op Ubuntu Host.
Lesson learned for this issue: DO NOT put Alias /zm directive in any of the site config files (vhosts)!
