Error check failed: '404 Not Found' for URL 192.168.1.141/decoder_control.cgi?command=4&user=admin&pwd=user=myuser&pwd=mypass
I find it strange that it is pulling a default user and pwd as well a defined one. I think it is pulling the defined one from the source path rtsp setting - regardless, it doesn't even look like it is getting to the point where it would even input a user/pass
I do get video in zoneminder from the camera.
I am on zoneminder 1.28.1.
I have tried just about every combination with every script I have and nothing.
I've done this on scripts after I couldtn't get them to work:
If running version 1.25 or newer, open the file. . file above has this change!!!!!
Comment the line "use ZoneMinder::Debug qw(:all);
Uncomment the line "#use ZoneMinder::Logger qw(:all);
If running version 1.26.5 or newer, open the file. !!
Change: "$self->{ua}->agent( "ZoneMinder Control Agent/".ZM_VERSION );"
With: $self->{ua}->agent( "ZoneMinder Control Agent/");
I called foscam and they confirmed it is a genuine foscam camera.
I have tried with usr=myuser&pwd=mypass and also with user=myuser&pwd=mypass
I have tried without anything in these fields
I have tried with the port on the end of the ip. 192.168.1.141:80
I have tried without the port on the end. 192.168.1.141
Yes, the camera is setup to use port 80 right now. I have also tried at the default 88 as well and all combination mentioned above.
Can someone please tell me what I'm missing or if you have a hidden script somewhere that works with this version of zoneminder and my camera (FI9821P V2).
In the camera Device Information it states the following:
System Firmware Version 1.5.2.11
Application Firmaware Version 2.21.1.143
any input at all will be very useful. I'm at the point where I may have to pull the plug on zoneminder as this is the first time I've used it and it isn't going so well.
I do have controllable PZT checked in the options and that option checked under control as well.
If there is more information that I can provide, please let me know and I will be more than happy to immediately provide it.
