1.28.107 on Ubuntu - which control script to use for a 8910W
McFuzz
Post by McFuzz » Fri Oct 16, 2015 7:39 am
Hello all,
Doing a fresh install on Ubuntu 14.04 using 1.28.107 from the iconnor PPA repo.
Having an issue figuring out which control script to use with my Foscam 8910W - the 8908W script moves the cam but does not have presets enabled and when I do enable presets - I get the following error message:
Can't access presetSet member of object of class ZoneMinder::Control::FI8908W
The 8918w script does not appear to move the camera at all regardless whether I change type from FFMPEG to remote... I get the following error messages:
Error REALLY check failed:'401 Unauthorized'
Cmd:HTTP::Request=HASH(0x2cefe10)
So... any ideas? Or should I use the old script from http://www.zoneminder.com/wiki/index.php/Foscam_Clones
Thanks!
Re: 1.28.107 on Ubuntu - which control script to use for a 8
Post by bbunge » Fri Oct 16, 2015 12:22 pm
If I remember there is a script for a 8918 that works for the 8910. Go back a few months in this forum and there is a write up for it.
bb
McFuzz
Post by McFuzz » Fri Oct 16, 2015 5:06 pm
After some trial and error - finally got it to work.
Thank you!!
