Has anyone made TinyCam work with Zoneminder?
washy75
Post by washy75 » Mon Aug 31, 2015 11:28 pm
I am a bit disappointed with tinyCam, can't really make it work with my Zoneminder installation, even after I bought the PRO version. Searched everywhere, even in this very forum but no luck.
My problem is that I can add my Zoneminder IP address to tinyCam but can't see anything at all. I go to "Manage Cameras"/"Scan Network"/"Advanced". I type in my IP address and credentials for my ZM installation. The ZM server is added apparently fine but can't see the list of cameras I have hooked up to my ZM server. When I check "Camera Status", all I see is that there's frames being received somehow but there's a "Dropped Frames: 100%" down bellow that bugs me. The only clue I could find here in this Forum is that someone noticed Monitor ID changed every time you add a new camera, then he deleted the first monitor and tinyCam didn't work anymore. I tried going on PHPMyAdmin on the server where ZM is installed and tried to change Monitor ID to 1 but I realised all I did was to change the name for it "Monitor 1". tinyCam PRO still doesn't work! I don't normally post on forums, because normally on my searches I find the answer, but I haven't found it yet. tinyCam developer doesn't answer anything, which I find very frustrating since people like me support his work, but never mind. Hope someone else here can give me some light into my case.
P.S.: BTW, Zoneminder works like a charm on ZMView, but I find it quite boring app, and was hopefull that tinyCam would be 100% better. I am wrong so far...
asker
Re: Has anyone made TinyCam work with Zoneminder?
Post by asker » Fri Dec 18, 2015 7:11 pm
I just released zmNinja in the play store. You need ZM 1.28.107 or above.
darmach
Post by darmach » Fri Dec 09, 2016 4:55 pm
Did you solve your issue? In TinyCam you need to select proper "channel" - its the same as camera ID in mysql table.
