Master Snapshots
Master Snapshots
I am switching to using packaging scripts that more closely follow debian's. This introduces some potential breakage, which is easily corrected.
Problem #1: zoneminder will not be automatically enabled in systemd. So after the update, zoneminder might not get started. To fix this do
sudo systemctl enable zoneminder
Problem #2: The cgi-bin dir has been moved from /usr/lib/cgi-bin to /usr/lib/zoneminder/cgi-bin. This will require editing your apache config.
Re: Master Snapshots
Addendums to this, now that I am releasing a new snapshot for ubuntu 1404.
apache2 config may contain old stuff. Look for /etc/apache2/conf-enable/zm.conf. You will want to remove it and do
a2enconf enable zoneminder
Also, in the options popup -> Paths, change PATH_ZMS to /zm/cgi-bin/nph-zms
The zmupdate scripts need to alter and create some tables. The zmuser account in mysql will need rights to do this.
I set up a test with Ubuntu 15.04 and installed the version from the iconnor/zoneminder-master PPA. Did not have success...
The database did not install in MySQL. I had to manually add the zm database (see Debian 8.1 How To if you want to do this)
Was not able to find the config file mentioned in the first post above. Did not get ZM to start.
Will keep trying and report success or failure...
Procedure for Ubuntu 14.04 using the master PPA
Add Repository
apt-get install software-properties-common python-software-properties
add-apt-repository ppa:iconnor/zoneminder-master
apt-get update
Install Zoneminder
apt-get install zoneminder
cd /usr/share/zoneminder/db
mysql --user=root --password=(root password) < zm_create.sql
grant select,insert,update,delete on zm.* to 'zmuser'@localhost identified by 'zmpass';
\q (enter) (to quit)
chmod 740 /etc/zm/zm.conf
Add delay to allow MySQL to start before Zoneminder
nano /etc/init.d/zoneminder
Add sleep 15 as shown:
start() {
sleep 15
echo -n "Starting $prog: "
Ctrl+o Enter to save
CTRL+x to exit
Create a new user
adduser www-data video
a2enmod cgi
a2enconf zoneminder
Start Zoneminder
service zoneminder start
Restart Apache
service apache2 reload
For Ubuntu 15.04
Add Repository
apt-get update
Install Zoneminder
Create a new user
Start Zoneminder
a2enmod cgi
a2enconf zoneminder
Restart Apache
service apache2 restart
