command line delete events
Zsolt
Post by Zsolt » Sat Jun 20, 2015 10:44 am
Hey,
something happened and my HDD is full. It looks like the filter did not work as desired.
Is there a way to make some empty space, like deleting events manually via console. I cant log in via the GUI, being sent back to the authentication page each time I enter my credentials.
Thanks in advance.
asker
Re: command line delete events
Post by asker » Sat Jun 20, 2015 11:25 pm
ZoneMinder has a filter that is enabled by default to run in the background called PurgeWhenFull. It removes events when your disk space reaches 95%. Unless you have manually disabled it, it will run. So are you sure you can't log in because your disk it full?
There are two ways, if that really is an issue:
a) sudo zmfilter.pl -f PurgeWhenFull (this will manually run the filter)
b) Go to your events directory and remove all JPEG files --> don't remove the monitor ID directories and soft links inside events - just the jpeg images - don't worry, zmaudit will take care of removing DB entries later
Zsolt wrote:Hey,
Thanks in advance.
Zsolt
Post by Zsolt » Mon Jun 22, 2015 7:44 am
100% sure.
df -h showed 0 under Avail.
I had a 50 meg zip file on the server, and as soon I deleted it, I was able to log in under zoneminder and run the filters manually.
I have the PurgeWhenFull and another filter set as "Run filter in background". Somehow something managed to "kill" `em.
AUDIT_CHECK_INTERVAL is also set to 900, and enabled.
Thanks for the tips, I've bookmarked them, so I'm covered if I need them in the future.
Baylink
Post by Baylink » Sun Aug 20, 2017 10:45 pm
Exhuming this thread for one potential reason:
I don't know if *ZM's* idea of 95% is *of the entire size of the drive*, or if it's *of the size of the drive less the percentage reserved for root at mkfs time. If it's the former, and the latter percentage is greater than 5% it will never clean up, since the drive can never get that full.
Users browsing this forum: No registered users and 0 guests
