Updating ZM 1.28 to use turbo-jpeg *after* it is set up
asker
Post by asker » Tue Mar 03, 2015 5:54 pm
I've set up an ubuntu 14.04 desktop with ZM. I installed ZM 1.8 using instructions in this link:
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
I'm now working on performance optimization, and discovered turbo-jpeg
I installed turbo-jpeg via the instructions provided (including creating the symlinks and doing an ldconfig
If I look at my /usr/lib for libjpeg it shows the right links
root@camerapc:/usr/lib# ls libj* -l
lrwxrwxrwx 1 root root    20 Feb 28 14:19 libjbig2dec.so.0 -> libjbig2dec.so.0.0.0
-rw-r--r-- 1 root root 92384 Nov 29  2012 libjbig2dec.so.0.0.0
lrwxrwxrwx 1 root root    34 Mar  3 12:01 libjpeg.a -> /opt/libjpeg-turbo/lib64/libjpeg.a
lrwxrwxrwx 1 root root    15 Feb 28 14:19 libjte.so.1 -> libjte.so.1.0.0
-rw-r--r-- 1 root root 47544 Dec 23  2013 libjte.so.1.0.0
Now how do I make sure ZoneMinder is using these libs and not some libjpeg library in another path?
thanks
asker
Re: Updating ZM 1.28 to use turbo-jpeg *after* it is set up
Post by asker » Tue Mar 03, 2015 6:56 pm
Okay, it looks like zmc/zma is still using libjpeg and not turbo. This is after I
a) added export LD_LIBRARY_PATH to /etc/init.d/zoneminder to point to turbo libs
b) did an apt-get uninstall zoneminder followed by an apt-get install zoneminder
Do I need to remove the zone minder package and compile from source? If so, how do I use the turbo libs and how to I ensure all my settings are not cleared?
thanks
r
oot@camerapc:/usr/lib/x86_64-linux-gnu# lsof | grep libjpeg | grep www-data
lsof: WARNING: can't stat() fuse.gvfsd-fuse file system /run/user/1000/gvfs
      Output information may be incomplete.
zmc       9491        www-data  mem       REG                8,5    281288    3285698 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.0.2
zmc       9491 9556   www-data  mem       REG                8,5    281288    3285698 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.0.2
zmc       9491 9557   www-data  mem       REG                8,5    281288    3285698 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.0.2
zmc       9491 9558   www-data  mem       REG                8,5    281288    3285698 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.0.2
zmc       9510        www-data  mem       REG                8,5    281288    3285698 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.0.2
zmc       9519        www-data  mem       REG                8,5    281288    3285698 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.0.2
zmc       9519 9553   www-data  mem       REG                8,5    281288    3285698 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.0.2
zmc       9519 9554   www-data  mem       REG                8,5    281288    3285698 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.0.2
zmc       9519 9555   www-data  mem       REG                8,5    281288    3285698 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.0.2
zma       9559        www-data  mem       REG                8,5    281288    3285698 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.0.2
zma       9561        www-data  mem       REG                8,5    281288    3285698 /usr/lib/x86_64-linux-gnu/libjpeg.so.8.0.2
Post by knight-of-ni » Tue Mar 03, 2015 7:43 pm
I think you really mean libjpeg-turbo. libjpeg-turbo contains the turbjpeg api wihin it.
http://www.libjpeg-turbo.org/About/TurboJPEG
Ubuntu has been using libjpeg-turbo as the default libjpeg library for some time now.
abauer@techeng-wks01:~/git/ZoneMinder/distros$ apt-file search /usr/lib/x86_64-linux-gnu/libjpeg.so.8.0.2
libjpeg-turbo8: /usr/lib/x86_64-linux-gnu/libjpeg.so.8.0.2
So you are in fact, already using it.
asker
Post by asker » Tue Mar 03, 2015 8:08 pm
Oh! *sheepish-grin*. I just finished recompiling source :lol: Looks like I wasted my time
I never knew about apt-file --> I just installed it and ran the same command. Based on reading it's help, it seems to be saying "libjpeg.so.8.0.2" is included in "libjpeg-turbo8" and no other package for ubuntu. So thusly, you can confirm that if I have that file, and ZM is using it, then that must have been installed by libjpeg-turbo8 which is what I was going for in the first place. Is that correct?
thanks!
