Hikvision DS-2CD2132-I
prenger745
Post by prenger745 »
I do not see a specific wiki-page for this model. Has anyone successfully used these cameras.
I have 4 currently installed and I am going to try some other Hikvision models' setting (from their specific wiki pages) to see what I can get working...but if someone already has them working, why re-invent the wheel?
I know I am going to kick myself for asking but from the wiki:
H.264 1080p megapixel IP dome camera [1] .
The camera I have working successfully with Zoneminder is running the following firmware:
TBC
High Bit Rate, Frame Rate, non-TCP and 1080p streaming cause smearing for me when using Zoneminder 1.26.3, but the following camera settings seem to be reliable:
TBC
You may get away with a higher Bit/Frame Rate and resolution, but the above work well for me.
What does 'TBC' stand for?
Thanks,
Dan
Re: Hikvision DS-2CD2132-I
Transcendentally Bloated Crap?
To Be Confirmed?
jfm
Post by jfm »
From context it would give meaning if it stands for: "To Be Completed"
c128
Post by c128 »
jfm wrote:From context it would give meaning if it stands for: "To Be Completed"
If it relates to this http://www.zoneminder.com/wiki/index.ph ... 2CD2732FIS, then jfm wins the prize :wink: .
Forgot I hadn't completed that - I've updated it now.
FWIW the 2CD2732FIS has been a great camera with Zoneminder, although it's the only Hikvision I own.
