Zone configuration
liderbug
Zone configuration
Post by liderbug »
I've tried to read up on Zones I've got a problem I've never had before and my experimentation is just not working. My stream is coming in, life is good and "a" frame if fubar and the entire frame is RED!!! flash and the next frame is just fine. Before I could pick "Best Med. Sens" and not have to do anything. I've tried Min/Max numbers. How do I get ZM to pitch the 1 frame in 25,000 that's bad.
Re: Zone configuration
My guess is that you are using ffmpeg and you are getting the red streak plague? Search this forum for streaking. There are plenty of recommendations...
