Send Command in the Event OPEN not when the event Close
Posted: Wed Oct 08, 2014 5:29 pm
Hi, I'm using my fixed cameras events to send a simple cURL command to the Foscam PTZ cameras.
It's simple, when an event alarm is detected it executes de cURL and moves the cameras, however, it just sends the command after the event is closed. Which is too late if the event is long. I'm using the "Filters" section to do it.
What I need is when the event starts it sends the command, is it possible with a standard installation of ZM or I need modules and alterations to the code to make it happen?
Thanks a Lot!!
Thanks a Lot!!
