Apache2 IP is different to zoneminder IP Address
Posted: Fri Sep 12, 2014 7:43 pm
Hi all, hope all is well.
i have installed zoneminder on linux mint, all good. But when I got a new cam, I had to change linux mint ip in order to acces the ip cam web interface in order to adjust/change the ip cam settings, which went well. I then shut the pc down to go home. The next day, start up the pc, change the ip back so it can be available on the network, all good, set the cam, got it working on zoneminder, sweet. But I noticed the ip address for apache2 is different to the ip address for zoneminder! can anyone help? As before apache and zoneminder had the same ip address (apache2 ip is 192.168.100.## zoneminder same ip but with /zm at the end) now apache last 2 digits is different to zoneminder last 2 digits, but it still work.
thank you
thank you
