Page 1 of 1
TD-9412M-D-FZ-PE-IR2 - how to get images?
Posted: Mon Jul 07, 2014 8:27 pm
by lista.email
Dear IP camera experts,
I have an IP camera, model TD-9412M-D-FZ-PE-IR2 - which is a TVT IP camera with POE support.
This camera is working beautiful with windows software and Internet Explorer.
I have it configured in LAN using IP 192.168.13.216.
Internet Explorer is able to display live images using htt p://192.168.13.216/WebCam.html (require authentication, user: admin and password).
Also is working as rtsp, vlc-2.1.2 is able to open (without password) rts p://192.168.13.216:554/
Trying to do the same things on linux, I am stuck. Firefox is not accepted and Vlc-2.x, pointing the same rtsp or http stream (after authentication) is showing invalid format message.
zoneminder, after configured first monitor, is able to detect activity on camera but is displaying a red image!
ZoneMinder-1.27 is running:
[root@zoneminder ~]# zmu -l
Id Func State TrgState LastImgTim RdIdx WrIdx LastEvt FrmRate
1 3 0 0 1404763396.26 47 47 0 43.29
Talking at technical department of those sold me camera, they confirmed that it has been tested and is working with Dahua NVR, for example, this model: NVR Dahua NVR3216-P
So, I am pretty sure that this camera should work also under linux, but I need some help to point me to the right direction.
Using it's configuration interface, I am able to see that it has also onvif section. This camera could be set to be client for:
- Dahua
- Hikvison
- Axxon
- Milestone
- Nuuo
- No Config
Now, ovif is setup for Dahua.
Please, help me get images on linux from this camera. I've attached a print screen from zoneminder which is configured as following:
General
Source Type: Remote
Function: Modect
Enabled: Tick
Maximum FPS: Empty
Alarm Maximum FPS: Empty
Source
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: 192.168.13.216
Remote Host Port: 80
Remote Host Path: /WebCam.html
Capture Width: 320
Capture Height: 240
Regards,
Alx
Re: TD-9412M-D-FZ-PE-IR2 - how to get images?
Posted: Tue Jul 08, 2014 6:20 pm
by linuxsense
You will want to use ffmpeg or vlc instead of 'remote' to have ZM read the stream.
Posted: Sat Jul 12, 2014 8:55 pm
by lista.email
no, vlc or ffmpeg is not working. See how I've solved it here:
ipcamtalk website
showthread.php?623-TD-9412M-D-FZ-PE-IR2-how-to-get-images
Posted: Sun Jul 13, 2014 4:33 am
by linuxsense
If they are not working you want to get them working...they work extremely well when properly configured. I run 6 720P cams at 15FPS and 100% JPEG quality and my server has a load average of about 0.75. Its good stuff.
