Error after install
merlim
Error after install
Post by merlim »
Hi all. I'm testing Zone Minder for first time. I used a centos 6.5 OS, I followed some tutorials and in end I access to zm page and I got a messed up page :
ZoneMinder  - - v'.ZM_VERSION.'', canEdit( 'System' ) ) ?>
/ '.$SLANG['Log'].'' ) ?>
<?=$SLANG['Refresh']?><?=$SLANG['Edit']?><?=$SLANG['Delete']?>
In error_log, I got :
[Fri May 09 15:46:42 2014] [error] [client 1.1.1.1] File does not exist: /var/www/html/zm/<, referer: http: / / 2.2.2.2/zm/
Any clue?
TheKorn
Re: Error after install
Post by TheKorn »
<? is the short entry code for PHP. My WAG is that you don't have short php entry on in your php.ini. (Or maybe php isn't even installed, but that's less likely.)
merlim
Post by merlim »
You were right : short_open_tag = on.
Thank you.
