Page 1 of 2
How update ZM from 1.25.0 to 1.26.3
Posted: Tue Sep 17, 2013 9:03 am
by topromotion
Hello!
I try to update my ZM from version 1.25.0 to 1.26.3 with
zmupdate.pl --version=1.25.0
but i have: Database already at version 1.25.0, update aborted.
What i must to do for update?
Re: How update ZM from 1.25.0 to 1.26.3
Posted: Tue Sep 17, 2013 5:41 pm
by 2Psycho
The command should be
 zmupdate.pl --user=root --pass=MYSQLROOTPASSWORD
All other actions will happen by it self
Posted: Tue Sep 17, 2013 7:36 pm
by topromotion
I try this command but i have - Database already at version 1.25.0, update aborted. Again.
Whats wrong?
Posted: Tue Sep 17, 2013 8:14 pm
by jameswilson
have you updated the rest correctly, or are you thinking this command will update the lot?
Posted: Wed Sep 18, 2013 6:44 am
by topromotion
I dont update nothing more. What i must to do after unzip archive with source?
Posted: Wed Sep 18, 2013 9:45 pm
by jameswilson
that command will only update your db structure etc. You need to update zm first.
Posted: Thu Sep 19, 2013 7:07 am
by topromotion
How i can update zm correctly?
I tried to do in the documentation - http://www.zoneminder.com/wiki/index.ph ... #Upgrading
but nothing came of it.
Posted: Thu Sep 19, 2013 7:10 am
by Magic919
How did you install it in the first place?
Posted: Thu Sep 19, 2013 2:03 pm
by aitzol76
I have the same problem as tropomotion. Version 1.25.0 installed via ubuntu repositories, and now can't get upgrade to version 1.26.3.
Posted: Thu Sep 19, 2013 2:05 pm
by knight-of-ni
aitzol76 wrote:I have the same problem as pepe. Version 1.25.0 installed via ubuntu repositories, and now can't get upgrade to version 1.26.3.
Did you uninstall the zm 1.25.0 deb package first before you tried to install 1.26.3 from source?
If you didn't then that is the problem.
sudo apt-get remove zoneminder
You can't have both on your system at the same time.
Posted: Thu Sep 19, 2013 9:00 pm
by topromotion
Magic919 wrote:How did you install it in the first place?
In first place i install it from sources
Posted: Thu Sep 19, 2013 10:00 pm
by Torsten73
Iconnor has released bis ppa for ubuntu 12.04. It works fine when the database path in zm.conf is correct.
It should be used on an standard preinstalled 1.25 setup.
Posted: Fri Sep 20, 2013 6:31 am
by Magic919
Ok. So you've downloaded the new 1.26.3 sources and unpacked, run the bootstrap.sh, run the configure command with options, run make and then make install. Did that all work?
Posted: Fri Sep 20, 2013 3:30 pm
by topromotion
Yes, its all works. What's next?
Posted: Fri Sep 20, 2013 5:43 pm
by Magic919
Great. After than just run zmupdate.pl with no arguments.
