cant start ZM - Strict Subs in use...?
kudos
Post by kudos »
i got 1.2.3 installed fine using the puppet module grate work thanks,
all was fine untill ZM stoped working, i went to restart it and now i have this error when i try and start it
 zm start
Starting ZoneMinder: Bareword "ZM_DYN_DB_VERSION" not allowed while "strict subs" in use at /usr/local/bin/zmpkg.pl line 150.
Bareword "ZM_CHECK_FOR_UPDATES" not allowed while "strict subs" in use at /usr/local/bin/zmpkg.pl line 228.
Bareword "ZM_DYN_DB_VERSION" not allowed while "strict subs" in use at /usr/local/bin/zmpkg.pl line 149.
Bareword "ZM_DYN_DB_VERSION" not allowed while "strict subs" in use at /usr/local/bin/zmpkg.pl line 151.
Execution of /usr/local/bin/zmpkg.pl aborted due to compilation errors.
failure
when i go to the web page i get
Not Found
The requested URL /undefined was not found on this server.
i tryed a database fix but did not fit it, says all is ok.
so i am at a loss as to what todo next.
thanks, rob
