Hi all,
I'm having a problem to configure a background delete event filter.
OS is Ubuntu 12.04. I have installed 4 ip-cams.
Is there anyone out there, who could explain me what's the correct setting to delete events older than X days ?
(Every thing I tried doesn't work)
Thanks in advance
Regards Michael
Delete events automatically after X days
Re: Delete events automatically after X days
Here's a sample, hope it helps. Remember to check the run on background when saving the filter, otherwise it will not be 'automatic'!
- deleteoldfilter.PNG (19.37 KiB) Viewed 2456 times
Thank you PacoLM very much,
it's working.
Best regards
Michael
it's working.
Best regards
Michael
