Hi all,
I´m installed an ubuntu appliance 1.25.0 in a VMware and add ip cammera, so when open any cammera it shows me a black screen, no image.
I read many errors in log, if somebody can help me, I could send log to analyze.
Thanks.
Black Screen on ubuntu appliance 1.25.0
Re: Black Screen on ubuntu appliance 1.25.0
Bellow is my event log of zoneminder appliance 1.25.0
Please can anybody help me?
Thanks.
2012-12-07 15:09:24.642812 web_php 5814 ERR socket_sendto( /tmp/zm/zms-528734s.sock ) failed: No such file or directory /usr/share/zoneminder/includes/functions.php 2322
2012-12-07 15:09:24.640851 web_php 5814 DBG LogOpts: level=DBG/DBG, screen=OFF, database=DBG, logfile=DBG->/tmp/zm/zm_debug.log.5814, weblog=INF, syslog=INF /usr/share/zoneminder/includes/logger.php 168
2012-12-07 15:09:20.611652 zms 6975 DB1 Can't glob '/tmp/zm/zmswap-m2/zmswap-q528734/*.*': 3 zm_monitor.cpp 3676
2012-12-07 15:09:20.611339 zms 6975 DB1 Cleaning swap files from /tmp/zm/zmswap-m2/zmswap-q528734 zm_monitor.cpp 3648
2012-12-07 15:09:20.610843 zms 6975 ERR Terminating, last frame sent time 10.030027 secs more than maximum of 10.000000 zm_monitor.cpp 3639
2012-12-07 15:09:16.602681 zms 6975 DB1 Got QUERY command, sending STATUS zm_monitor.cpp 3188
2012-12-07 15:09:11.091335 zms 6975 DB1 Got QUERY command, sending STATUS zm_monitor.cpp 3188
2012-12-07 15:09:10.088334 zms 6975 WAR Unable to store frame as shared memory invalid zm_monitor.cpp 3624
2012-12-07 15:09:10.071575 zms 6975 DB1 Loaded monitor 2(teste), 0 zones zm_monitor.cpp 2509
2012-12-07 15:09:10.071431 zms 6975 DB1 Monitor teste IBC = 40, WUC = 25, pEC = 10, PEC = 10, EAF = 1, FRI = 1000, RBP = 7, FM = 0 zm_monitor.cpp 462
2012-12-07 15:09:10.071277 zms 6975 DB1 Monitor teste LBF = '%N - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0 zm_monitor.cpp 461
2012-12-07 15:09:10.070812 zms 6975 DB1 Monitor teste has function 2 zm_monitor.cpp 460
2012-12-07 15:09:10.062345 zms 6975 DB1 Initialised zone 0/All - 1 - 640x480 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0, OF: 0 zm_zone.cpp 50
2012-12-07 15:09:10.062031 zms 6975 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results zm_monitor.cpp 439
Thanks.
dunno,
did you try with only one camera installed in zoneminder ?
how much memory did you allow for the vm?
where did you get the, I'm guessing, vdi ?
evil doers beware, someone is watching you,
hopefully me!
hopefully me!
