I'm working with the Airlink Smurf AM series (not to be confused with the A series).
I am able to get a video stream through VLC using this unusual looking RTSP path:
rtsp://192.168.0.156:554/user=admin&password=&channel=0&stream=0.sdp?
According to the Codec Information:
Codec: H264 - MPEG-4 AVC
Resolution: 1280x720
Decoded Format: Planar 4:2:0 YUV
In ZoneMinder I am unable to get video at all.
I have tried both Remote (tried HTTP and RTSP) and FFMPEG source types, but to no avail.
I thought if the path works for VLC, it also ought work for FFMPEG.
I am happy to provide any additional information about the cameras or my setup.
Also, the camera manufacturer provided me with an ONVIF package for the camera. A cursory look didn't turn up ONVIF options in ZM. If the camera will work with ZM over ONVIF, that may be an alternate solution for me.
Thank you in advance
New Airlink Camera, not working - help
Re: New Airlink Camera, not working - help
Should work with ffmpeg. Any error logs?
