Page 1 of 1
EasyN HS-696L-B0L7
Posted: Sun Feb 05, 2012 1:53 pm
by 2Psycho
I have been working to get my EasyN HS-696L-B0L7 to work.
It has taken a while but I have managed to get to work with ZoneMinder 1.25.0 for 90% satisfaction.
Nomarlly the device should be able to get a resolution from 702 * 576.
Unfortunately so far I manage only to get half this resolution.
The source I used:
General
Source = remote
Source
Remote = HTTP
Remote method = simple
Remote host = username:password@ip_adres
Remote path = /tmpfs/auto.jpg
Capture width = 352
Capture heigth = 288
The camera should be able to stream via rtps but I am not able to manage this.
So when somebody has a good solution for this I am willing to try this :D
According to my findings this stream link should simular to user:pass@ip_address:port/11
When I link zoneminder to this I get Quicktime format errors?
You have to create a new control to be able to use PTZ
Main
For the control capability the Name of the file and the protocol should be the same
at least otherwise it didn't work for me.
Move
Select can move
Pan
Select can pan
Tilt
Select can tilt
Zoom
Select can zoom
Focus
Select can focus
Presets
Select can Has Presets
Num Presets = 16
Select Has Home Preset
Select can set presets
Pan Tilt Zoom Control see attached file
I hope this is useful for you all please get me posted when you have improvements to this :)
Re: EasyN HS-696L-B0L7
Posted: Sun Feb 05, 2012 5:46 pm
by therese
I have the EasyN FS-613B-M166 IP PTZ camera and have succeeded in getting the video to work but not able to control the PTZ function. If you look on my post there are some of my settings. Under the control settings what control type did you use or did you have to create one. Thanks.
