ZoneMinder 1.25 & eyeZM 1.3
Snaki4
Post by Snaki4 » Sat Nov 26, 2011 1:45 pm
Good afternoon.
I've a problem with configuration of ZM 1.25 and eyeZM 1.3.
ffmpeg everything looks like good, ZM 1.25 working as expected as well, but I can't see live feed from iPhone.
I see thumb image but all times get timeout and stream is not showing on the device.
Can somebody give an idea how to fix it please?
(Ubuntu 11.10, ffmpeg latest from svn with h264, zm 1.25 + eyeZM from ZM package, eyeZM 1.3 client on iPhone)
Thanks.
Snaki4
Re: ZoneMinder 1.25 & eyeZM 1.3
Post by Snaki4 » Wed Nov 30, 2011 2:47 pm
problem were fixed with ffmpeg re-compilation
monex
Post by monex » Sun Dec 04, 2011 1:22 pm
I discussed with someone having a similar issue. First thing is, ZoneMinder 1.25.x includes eYe zm but not httpsegmenter. You have to donwload the p2fs3 version from http://eyezm.com/files.php and only compile compile and install the httpsegmenter from the downloaded archive. This solved the issue and hopefully it does for you.
Hope this helps
Snaki4
Post by Snaki4 » Wed Dec 07, 2011 12:39 pm
monex wrote:Hi,
Hope this helps
It was a first issue also there was some issue with exec (shellexec) command to start httpsegmenter, zmstreamer and ffmpeg work together and and start streaming.
All issues were fixed as I told.
Anyway, thx for the help.
