Logitech webcam won't show display
fedora
Post by fedora »
Hello.
sorry if this been posted before but im desperate!
i've installed zoneminder on ubuntu 11.04, fedora15 & centos5.6 successfully
and now im trying zoneminder virtual appliance.
im using Logitech Pro 4000
the Webcam is working FINE with Cheese and Camorama
added the camera in the "add new monitor" option and its always Black\Blank screen!
been googleing about it for DAYSSS but cant find any solution for this :evil:
thanks for ANY help :)
bb99
Re: Logitech webcam won't show display
Post by bb99 »
fedora
Post by fedora »
thanks for your reply.
after following the instructions... still no success!
and now i cant load the zoneminder webpage at all ! :cry:
fedora
Post by fedora »
ok just 1 mistake
after a reboot i can login to the zoneminder webpage again
but still after adding the camera its just Black\Blank screen!
PacoLM
Post by PacoLM »
Have a look to your logs (/var/log/syslog) and check if it complains about shared memory settings.
fedora
Post by fedora »
ok not really sure what im suppose to look inside the file
but i posted a screenshot of what look to me the most relevant lines!
is this the right part?
p.s
forgot to mention im running the machine inside VMware Workstation8
PacoLM
Post by PacoLM »
Create a file called checksharedmemory.sh with these lines and chmod +x:
#!/bin/sh
# Copyright (C) 2010 Chris "Pada" Kistner
# Modified by PacoLM to check only shared memory settings
# if you find errors, check that coreutils are installed, if not, run the command below
# apt-get -y install coreutils bc
echo "--- Checking memory setting..."
page_size=$(getconf PAGE_SIZE)
mem_bytes=$(awk '/MemTotal:/ { printf "%0.f",$2 * 1024}' /proc/meminfo)
mb=1048576
mem_bytes_mb=$(expr $mem_bytes / $mb)
shmmax=$(echo "$mem_bytes * 0.90" | bc | cut -f 1 -d '.')
shmmax_mb=$(expr $shmmax / $mb)
shmall=$(expr $mem_bytes / $page_size)
shmmax_cur=$(sysctl -n kernel.shmmax)
shmmax_cur_mb=$(expr $shmmax_cur / $mb)
shmall_cur=$(sysctl -n kernel.shmall)
echo "-- Total memory = $mem_bytes B = $mem_bytes_mb MB"
echo "-- Page size = $page_size B"
echo "-- Current kernel.shmmax = $shmmax_cur B = $shmmax_cur_mb MB"
echo "-- Current kernel.shmall = $shmall_cur pages"
if [ "$shmmax" -eq "$shmmax_cur" ] && [ "$shmall" -eq "$shmall_cur" ]; then
    echo "-- Recommended shm values already set"
else
    echo "-- Recommended: kernel.shmmax = $shmmax B = $shmmax_mb MB"
    echo "-- Recommended: kernel.shmall = $shmall pages"
fi
# Done
echo "--- Done."
Run the script and get the values, copy the values at the end of the file /etc/sysctl.conf, for instance:
kernel.shmall = 128350
kernel.shmmax = 473149440
Reload the values using sysctl -p , or reboot
Hope it helps,
PacoLM
fedora
Post by fedora »
thanks
been following the instructions... but cannot run the script!
was trying also chmod u+x
please check my screenshot
PacoLM
Post by PacoLM »
Here's attached, I think you removed the #.
checksharedmemory.zip
(818 Bytes) Downloaded 501 times
fedora
Post by fedora »
ok finally was able to run the script!
copied the values
(as you can see in the screenshot the sysctl.conf already had values so i added # to them)
anyway i tried adding the camera again with PAL\NTSC
and still Black screen :(
whats wrong with that ?
FullMoonMadness
Post by FullMoonMadness »
I just got a Logitech Quickcam E 3500 going, albeit at a low resolution. I'd recommend starting with the lowest resolution. Once picture is working, then you can graduate to higher resolutions.
The pdf at this link came in handy: http://www.google.com/url?sa=t&rct=j&q= ... NQ&cad=rja
I opened terminal and ran "lsusb". The last four digits of my ID corresponded with some of the info in the pdf.
