On Debian Squeeze I have a ZM v1.24.2 (installed from official repository) and four ip cam Sharkx IP306.
I have try to modify settings as http://www.zoneminder.com/wiki/index.php/Y-Cam but when I
clic on the name of the cam I have a blank screen with only the control panel on the top... what is the reason ? There is a lost plug-in on ZM ?
When I digit on a web browser ip_cam/stream.jpg and ip_cam/snapshot.jpg I can see the movies/pictures but if I digit ip_cam/stream.av start a file download...
GbMax78
Y-Cam - Sharkx IP306
Re: Y-Cam - Sharkx IP306
Check your shared memory settings, search the topic on the forum, it's plenty of information.
Ok I will search on the forum, for shared memory you mean the memory of the server where run ZM ? CPU and memory usage is very low the same for HD free space because on this machine I haven't a desktop...PacoLM wrote:Check your shared memory settings, search the topic on the forum, it's plenty of information.
GbMax78
P.S.
I have find http://www.zoneminder.com/forums/viewtopic.php?p=37678 my problem is the same of a lot of users... tomorrow I will ceck the available memory...
