Fail2Ban on Ubuntu 11.04 + Zoneminder 1.24.4
gmar_87
Post by gmar_87 » Sat Aug 20, 2011 4:05 am
I have installed Fail2Ban and got it working with SSH, but i can't find the correct log for Zoneminder logins and Webmin logins...
Does any one know where failed login attempts to Zoneminder via HTTP and Webmin via HTTPS are stored?
I have checked /var/log/apache2 but doesn't seem to log there...
gmar_87
Re: Fail2Ban on Ubuntu 11.04 + Zoneminder 1.24.4
Post by gmar_87 » Wed Aug 24, 2011 10:28 am
Does any one know how to log login failures to zoneminder?
FeraTechInc
Post by FeraTechInc » Thu Aug 25, 2011 12:58 am
Here is a start. To be honest though there is no easy way since it depends on how the authentication is handled by zonerider.
http://www.jquantlib.org/index.php/Prot ... _on_Debian
gmar_87
Post by gmar_87 » Sun Aug 28, 2011 7:29 am
FeraTechInc wrote:Here is a start. To be honest though there is no easy way since it depends on how the authentication is handled by zonerider.
Thanks FeraTechInc, but I'm having trouble locating where Zoneminder logs authentication. It looks like its not logged at all!
Do you know how authentication to Zoneminder is handled and how to activate logging for this?
gmar_87
Post by gmar_87 » Mon Aug 29, 2011 9:29 am
Got Webmin logins working with Fail2Ban. Add this to jail.conf
[webmin-iptables]
enabled = true
port = webmin
filter = webmin-auth
logpath = /var/log/auth.log
maxretry = 3
Still trying to get Zoneminder login page working...
gmar_87
Post by gmar_87 » Mon Sep 05, 2011 12:34 pm
Finally had some more time to look into this and got it working! :)
Failed web logins are now logged to apache error log.
I modified the userLogin function in /var/www/zm/includes/functions.php to create log entries on failures.
function userLogin( $username, $password="", $passwordHashed=false )
    global $user, $cookies;
    $dbUsername = dbEscape($username);
    $dbPassword = dbEscape($password);
    if ( ZM_AUTH_TYPE == "builtin" )
        if ( $passwordHashed )
            $sql = "select * from Users where Username = '".$dbUsername."' and Password = '".$dbPassword."' and Enabled = 1";
        else
            $sql = "select * from Users where Username = '".$dbUsername."' and Password = password('".$dbPassword."') and Enabled = 1";
    else
        $sql = "select * from Users where Username = '".$dbUsername."' and Enabled = 1";
    $_SESSION['username'] = $username;
    if ( ZM_AUTH_RELAY == "plain" )
        // Need to save this in session
        $_SESSION['password'] = $password;
    $_SESSION['remoteAddr'] = $_SERVER['REMOTE_ADDR']; // To help prevent session hijacking
    if ( $dbUser = dbFetchOne( $sql ) )
        $_SESSION['user'] = $user = $dbUser;
            $_SESSION['passwordHash'] = $user['Password'];
    else
        unset( $user );
        //Added 05/09/2011 by John Marzella
        //Log username and password auth failure from web interface
        error_log( "Unable to authenticate ZM web user with username '$username' and password '$password'" );
    if ( $cookies )
        session_write_close();
I created a Fail2Ban filter called zoneminder.conf
# Fail2Ban configuration file
# Author: John Marzella
# Created : 05/09/2011
[Definition]
# patern :      [client 10.1.2.3] Unable to authenticate ZM web user with username 'admin' and password '', referer: http://10.1.2.3/index.php
#               [client 10.1.2.3] Unable to authenticate ZM web user with username 'admin' and password 'admin', referer: http://10.1.2.3/index.php
# Option:  failregex
# Notes.:  regex to match the password failure messages in the logfile. The
#          host must be matched by a group named "host". The tag "<HOST>" can
#          be used for standard IP/hostname matching and is only an alias for
#          (?:::f{4,6}:)?(?P<host>[\w\-.^_]+)
# Values:  TEXT
failregex = [[]client <HOST>[]] Unable to authenticate ZM web user*
# Option:  ignoreregex
# Notes.:  regex to ignore. If this regex matches, the line is ignored.
# Values:  TEXT
ignoreregex =
and added this to Fail2Ban's jail.conf
[zoneminder]
enabled = true
port    = http,https
filter  = zoneminder
logpath = /var/log/apache*/*error.log
maxretry = 3
Now clients are blocked after 3 failed login attempts.
gavinp
Post by gavinp » Sun Jul 28, 2013 4:32 pm
Thanks for posting this - an old post I know but a good one!
This also works a treat on Ubuntu 12.04LTS server and Zoneminder 1.25
Cheers
Gavin
gmar_87
Post by gmar_87 » Wed Mar 30, 2016 10:22 am
I've added a fail2ban filter and jail conf for Zoneminder 1.29.0.
https://github.com/fail2ban/fail2ban/co ... arz:master
viewtopic.php?f=9&t=24470
Users browsing this forum: No registered users and 17 guests
