Page 1 of 1
Y-Cam Black YCB004 no worky (IP camera)
Posted: Thu Apr 28, 2011 11:06 am
by purps
Hi All. Having a bit of a problem getting my Y-Cam Black YCB004 working, can't seem to find much documentation or any posts about it.
Am running ZoneMinder 1.23.3 on Kubuntu 8.10. Have x3 Panasonic BL-C10s that are working perfectly on Mocord, but aren't having any joy with the Y-Cam. The IP address is green, as is the "Mocord", which I thought meant that all was well? I just get a blank square, and no recordings.
I have the remote host name in as "admin:pass@192.168.80.XXX" and the path as "/stream.jpg", and I checked that "h_t_t_p_://admin:pass@192.168.80.XXX/stream.jpg" works in a browser (it does). Camera is currently on 640x480 (would like to use this resolution ideally), but have tried it on 320x240 (although this turns the IP red!). I have also tried it on "Monitor".
Any and all help would be very much appreciated!
Cheers,
Matt.
Re: Y-Cam Black YCB004 no worky (IP camera)
Posted: Thu Apr 28, 2011 12:18 pm
by PacoLM
Shared memory?
Run this script and change the settings to check if anything changes:
#!/bin/sh
# Copyright (C) 2010 Chris "Pada" Kistner
# Modified by PacoLM to check only shared memory settings
# NOTE: -f you find errors, check that coreutils are installed, if not, run the command below
# apt-get -y install coreutils bc
echo "--- Checking memory setting..."
page_size=$(getconf PAGE_SIZE)
mem_bytes=$(awk '/MemTotal:/ { printf "%0.f",$2 * 1024}' /proc/meminfo)
mb=1048576
mem_bytes_mb=$(expr $mem_bytes / $mb)
shmmax=$(echo "$mem_bytes * 0.90" | bc | cut -f 1 -d '.')
shmmax_mb=$(expr $shmmax / $mb)
shmall=$(expr $mem_bytes / $page_size)
shmmax_cur=$(sysctl -n kernel.shmmax)
shmmax_cur_mb=$(expr $shmmax_cur / $mb)
shmall_cur=$(sysctl -n kernel.shmall)
echo "-- Total memory = $mem_bytes B = $mem_bytes_mb MB"
echo "-- Page size = $page_size B"
echo "-- Current kernel.shmmax = $shmmax_cur B = $shmmax_cur_mb MB"
echo "-- Current kernel.shmall = $shmall_cur pages"
if [ "$shmmax" -eq "$shmmax_cur" ] && [ "$shmall" -eq "$shmall_cur" ]; then
   echo "-- Recommended shm values already set"
else
   echo "-- Recommended: kernel.shmmax = $shmmax B = $shmmax_mb MB"
   echo "-- Recommended: kernel.shmmall = $shmall pages"
fi
# Done
echo "--- Done."
Hope it helps, credits goes to the author of the script "Pada",
PacoLM
Posted: Sun May 01, 2011 3:45 pm
by purps
Thank you very much indeed for the reply.
Is what shared memory? The camera? The computer in question has its own dedicated graphics card if that's what you are referring to? Sorry if that's not what you mean!
I appreciate you showing me that script; I will need to read up as to what it does before I run it (I assume that information is here somewhere, will look shortly). ZM is installed on my home automation system, so don't want anything untoward to happen!
Cheers,
Matt.
Posted: Sun May 01, 2011 4:04 pm
by purps
Ok, this is what I got:
-- Total memory = 2121965568 B = 2023 MB
-- Page size = 4096 B
-- Current kernel.shmmax = 33554432 B = 32 MB
-- Current kernel.shmall = 2097152 pages
-- Recommended: kernel.shmmax = 1909769011 B = 1821 MB
-- Recommended: kernel.shmmall = 518058 pages
--- Done.
Is this referring to swap space? Is it swap space that I have to increase?
Cheers,
Matt.
Posted: Wed May 04, 2011 9:30 pm
by purps
Sorry for the stupid questions - I got it going with a little research, was just panicking about getting it working properly before I went away.
Had to increase the kernel.shmmax value (FAQ, of course). Thank you for the script, could not have done it without that.
Cheers,
Matt.
